Boost issue
Old Dec 3, 2011 | 08:20 PM
crxkid24's Avatar
Default Boost issue
It's a b18c1 turbo. I can't get it to boost past 15 psi. First had a ebc and it didn't work. So tried a mbc and still can't get past 15 psi. Checked and fixed all boost leaks. Next thing I tried was took off the wastegate and made a block off plate. So I completely eliminated the wg. Now the turbo should boost til it can't no more. Boost cut at 20 psi just in case. Go for a ride and turbo still won't make it past 15 psi. My buddies are telling me it's the turbo. Its a precision t68. No shaft play. Turbo seems fine in my opinion. Anyone ever experience this? Or have any ideas?
Old Dec 3, 2011 | 08:22 PM
Dc4LsTeG's Avatar
EK9
Default Re: Boost issue
What's it tuned on?
Old Dec 3, 2011 | 09:52 PM
dk=gsr's Avatar
How many bar map sensor are you running?
Old Dec 4, 2011 | 11:00 AM
crxkid24's Avatar
Hondata s300 and it's on a 3 bar map
Old Dec 4, 2011 | 04:37 PM
crxkid24's Avatar
Anyone?
Old Dec 17, 2011 | 08:00 PM
dk=gsr's Avatar
don't have any idea on what it is.
best thing to do is try a different turbo and see if you can go past 15psi with it.
Old Dec 17, 2011 | 11:00 PM
EsotericImage's Avatar
Retired Moderator
could be a restriction somewhere..?
what manifold?
what size downpipe and exhaust piping?
Old Dec 18, 2011 | 04:23 PM
Thomascivicsi's Avatar
What type of exhaust are you running???
Old Dec 19, 2011 | 12:52 AM
turbohatch96y7's Avatar
Boost,leak? Ripped coupler loose clamp. Cracked turbine housing blown gaskets...
ekturbo13
Feb 20, 2011 08:39 PM
Nisif
Feb 11, 2006 12:35 PM
prabtej_si
Jan 25, 2005 09:02 PM
slwazgsr
Jun 23, 2003 03:45 AM
