rear wheel speed sensor
Old Dec 24, 2011 | 02:58 PM
dropped93ex's Avatar
Default rear wheel speed sensor
I have a 93 civic ex non abs and I'm looking to add a rear wheel speed sensor for when i switch to aem so I can do boost by speed .. any idea how to add the wheel speed sensor I haven't found anything while searching
Old Dec 24, 2011 | 03:44 PM
Tony the Tiger's Avatar
Default Re: rear wheel speed sensor
The AEM picks up your vehicle speed signal from the transmission VSS sensor.
AEM's traction control function doesn't use wheel speed sensors either.. It does it through calculation from acceleration rate vs RPM change over time.
So adding a rear wheel speed sensor will not accomplish anything in your case.. Unless you plan on adding a Racelogic traction control, then you will need all 4 wheel speed sensors
ColeCooper90
Jan 4, 2019 12:35 PM
hello1320
Dec 23, 2009 06:48 AM
Benard
Suspension & Brakes
Nov 10, 2008 08:43 AM
Mikey3000
Nov 1, 2008 12:02 AM
ninesecteg
Feb 17, 2003 07:53 AM
