HELP: CAR RUNING LEAN WITH TURBO
Old Oct 19, 2004 | 08:45 AM
94_civicEx's Avatar
Default HELP: CAR RUNING LEAN WITH TURBO
i need help i have a 94 civic ex with a greddy turbo kit on it and the check engine came on and it was an always run lean code so i bought some 310cc injector and run it with an safc controller my setting are:
crossover
30 60
low throttle high throttle
1k-35 1k-34
2k-4k-34 2k-27
5k-27 3k-27
4k-8k-19
i don't know how to set the safc and can anyone help?
Modified by 94_civicEx at 7:42 PM 10/19/2004
Modified by 94_civicEx at 7:43 PM 10/19/2004
Old Oct 19, 2004 | 09:04 AM
project dc2's Avatar
Default Re: HELP: CAR RUNING LEAN WITH TURBO (94_civicEx)
are those negative values ? with 310's i dont even think you should be leaning them out too much except for idle and low speed driving. this isnt the afc hack.
93turbo16's Avatar
I think your problem is the map is seeing boost. Do you have a missing link or check valves installed? Why not get 450cc injectors?
Old Oct 19, 2004 | 09:15 AM
94_civicEx's Avatar
ya those are negative values and no it not hack and what is hack i'm new to this?
i have no idea how to tune the safc any help will do
and why 450cc injectors
Old Oct 19, 2004 | 10:26 AM
93turbo16's Avatar
well do you have the blue box a missing link or what? if not you are throwing a code because the ecu is seeing boost. 450s and set the settings to about -35-40 across the board, that is the baseline around here. I don't run it anymore but I have mine at around -30, and it ran just fine.
Old Oct 19, 2004 | 10:41 AM
94_civicEx's Avatar
Default Re: (93turbo16)
yes i got a missing link
my setting is at 34 all cross
still got an always run lean code
wshondaman
Dec 24, 2004 01:45 PM
Kutsuju Racing Pres
Nov 10, 2004 02:13 PM
BME1986
Sep 24, 2004 08:57 AM
Pandahatch
Sep 6, 2004 06:07 PM
anothaRRR
Nov 19, 2003 05:33 AM
