b16 ecu
Old Oct 18, 2004 | 05:15 PM
majek's Avatar
Default b16 ecu
I finally made up my mine and im going to be building a crvtec dart b20 block with a b16a2 head and I was wondering if I could still use my b16 computer or is it going to run like crap? What other computer could I run that would make it run like a champ? Thanks
Old Oct 18, 2004 | 05:56 PM
toolowsol's Avatar
Default Re: b16 ecu (majek)
you can go with standalone, hondata, uberdata, or a number of other options, but your best bet is to socket the p30 ecu you have and run some different fuel and ignition tables to maximize your performance. Look into uberdata as a cost effective way to do this, or if you have lots of money to burn and don't want any hassles check out hondata.
Old Oct 18, 2004 | 11:19 PM
majek's Avatar
So my stock si computer will do fine for a b20 vtec and do I stick with the stock 240cc injectors or do I have to upgrade them and can I use a b16 oil pick up, b16 oil pan, b16 water pump and gsr timing belt for the b20 block.
g2s
Engine Machining & Assembly
Jun 8, 2016 05:37 AM
Jo$e L@go
14
May 10, 2010 09:08 AM
ivan93egreppin210
Mar 25, 2009 02:26 PM
majek
Oct 18, 2004 05:36 PM
charjacq
Aug 21, 2002 03:14 PM
