clutch up grade?
Old Oct 16, 2004 | 01:10 AM
crispydee's Avatar
Default clutch up grade?
Can anyone recoomend a nice clutch that will stand 300bhp that is good for daily driving and will not make my left leg look like one of those bird russian shot putter's.
I dont want it to feel like a stupidly up rated clutch because ive had a car with a paddle clutch before and it was a nightmare in traffic.
Old Oct 16, 2004 | 01:35 AM
tegmech's Avatar
clutchmaster stage 3...good clutch imo.
Old Oct 16, 2004 | 05:02 AM
Boostedcivicsi's Avatar
Default Re: (tegmech)
im using a act street strip clutch making around 380 whp, its held up for the past 3 years. dont go overkill, not unless you plan on making 400+
Old Oct 16, 2004 | 08:47 AM
mpintegra96's Avatar
Default Re: clutch up grade? (crispydee)
im using clutchmasters stage 3 with there flywheel, its handles my car 7psi 233whp and 10psi 303whp, and clutchmasters the pedal pressure was lighter than stock in my car
Old Oct 16, 2004 | 09:58 AM
Alchemist's Avatar
Default Re: clutch up grade? (mpintegra96)
Action 2KS, full face kevlar, engages like stock, slightly higher pedal pressure, will support 375hp.
Old Oct 16, 2004 | 12:32 PM
Ri5e's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mpintegra96 &raquo;</TD></TR><TR><TD CLASS="quote">im using clutchmasters stage 3 with there flywheel, its handles my car 7psi 233whp and 10psi 303whp, and clutchmasters the pedal pressure was lighter than stock in my car</TD></TR></TABLE>
I'm using a Clutchmasters Stage 4 + 8.5 LB Flywheel. Awesome combo and the pedal is definetly lighter than stock. Very streetable and holds power good!
Old Oct 16, 2004 | 01:13 PM
crispydee's Avatar
Ive seen some of the Act clutches on ebay secondhand DONT worry in not buying a second hand clutch! They seem to be a fair price. What sort of price are the clutchmaster stage 3/4. Im in the uk so ive got to add a load of postage on top
Old Oct 16, 2004 | 05:41 PM
skunk2eg's Avatar
ACT = good investment
Old Oct 16, 2004 | 05:53 PM
CivicGSR225's Avatar
ACT XTSS with an Extreme Pressure plate.... Good till 319ft/lbs torque...its stiffer than stock, but it is still a street clutch. I actually like the feel of my clutch way better than any stock clutch.
Old Oct 17, 2004 | 04:45 AM
crispydee's Avatar
Default Re: (CivicGSR225)
I dont mind it a little stiffer as i is light anyway. What sort of money do they go for?
Old Oct 17, 2004 | 06:40 AM
StolenTeg's Avatar
Default Re: (crispydee)
I got my Brand New Clutchmaster stage 3 for 250 shipped without throwout and pilot bearing, Brought both bearing from eclutchmaster for 65 shipper. So together i paid 315 for my Eclutchmaster stage 3...
Old Oct 17, 2004 | 07:02 AM
BLK JDM's Avatar
Default Re: (StolenTeg)
I'll vouch for both ACT and SPEC clutches!! ACT has a harder pedal feel but you'll get used to it. SPEC has soooo many options it's unbelievable. I'd go w/ their double diaphram pressure plate and full kevlar street disc!!
Old Oct 17, 2004 | 08:07 AM
YashiMotors's Avatar
what clutchmasters URL webpage?
Old Oct 17, 2004 | 02:25 PM
dr_latino999's Avatar
Default Re: (YASH)
http://www.clutchmasters.com/shop/
Old Oct 17, 2004 | 09:54 PM
crispydee's Avatar
Default Re: (dr_latino999)
Had a look on there, a stage three sounds best for my needs, but when i put the info in to get the price i get a price of $570 + shipping to the UK. Ive put the car in as a civic delsol 1.6 vtec dohc. Am i right in thinking thats got the B16a1/2 engine in it. Not sure if it will be the same as my UKDM B16a1
Old Oct 17, 2004 | 11:17 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crispydee &raquo;</TD></TR><TR><TD CLASS="quote">Had a look on there, a stage three sounds best for my needs, but when i put the info in to get the price i get a price of $570 + shipping to the UK. Ive put the car in as a civic delsol 1.6 vtec dohc. Am i right in thinking thats got the B16a1/2 engine in it. Not sure if it will be the same as my UKDM B16a1</TD></TR></TABLE>
Yes you have the Y2 tranny on your B16A1 ...the B16A2 has the Y21 tranny.
They have different splines. You need a clutch that is made for a cable tranny on a b series engine...i donno what that was i USA.
Old Oct 18, 2004 | 01:10 AM
crispydee's Avatar
Default Re: (YASH)
Ok thanks for that. I will have to send some emails to them to make sure its right. Thanks for all the help guys.
Yash, Did you sort your O2 sensors out on the end? i have done what i sound about linking them and ive had no problems and car is smooth in and out of boost with a nice steady idle.
Old Oct 20, 2004 | 11:58 AM
Honda Hick's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StolenTeg &raquo;</TD></TR><TR><TD CLASS="quote">I got my Brand New Clutchmaster stage 3 for 250 shipped without throwout and pilot bearing, Brought both bearing from eclutchmaster for 65 shipper. So together i paid 315 for my Eclutchmaster stage 3...</TD></TR></TABLE>
Where did you get your clutch from?
Rican83
Jan 19, 2012 12:09 PM
Benjithx
Nov 14, 2004 12:00 AM
dohcdelsol
14
Aug 16, 2004 10:42 AM
Que_Lude
Oct 27, 2003 06:52 PM
SubieDude
Oct 22, 2002 07:23 PM
