broken fitting in block
Old Oct 17, 2004 | 02:11 PM
maxspeedhonda's Avatar
Default broken fitting in block
Ok, I was just finishing up my motor this weekend to get it started up. I just installed the endyn breather kit. One of the plugs that needed to be removed is very close to the oil feed line. Well in the process of removing the plug, the oil fitting sheared off in the back of the block. How have you guys dealt with this before. Would I possibly be able to plug that hole and just use an oil filter sandwich adapter instead? I have spent a TON of time getting this motor back together and I honestly do not feel like pulling it apart again just because of this lousy fitting. You guys got any opinions?
Old Oct 17, 2004 | 02:36 PM
evosol's Avatar
Default Re: broken fitting in block (maxspeedhonda)
i know its very tight back there but you can always try an "easy out" tool, you can find them at Sears.
Old Oct 17, 2004 | 02:42 PM
Default Re: broken fitting in block (evosol)
hmm... never heard of it. You could possibly describe it?
Old Oct 18, 2004 | 04:36 AM
bump
Old Oct 18, 2004 | 05:30 AM
b_ron007's Avatar
go to anywhere autoshop and they'll know what it is. i think there have been soo many people that have done this.......i am one of them. a ez-out will take care of ur situation.
Old Oct 18, 2004 | 05:49 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: (b_ron007)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b_ron007 &raquo;</TD></TR><TR><TD CLASS="quote">i think there have been soo many people that have done this.......i am one of them. </TD></TR></TABLE>
And yet for some reason people still insist that it is ok to have there oil lines setup like this
I run an oil distribution block (homemade from lowes) on my firewall
That is the way to go
Old Oct 18, 2004 | 05:52 AM
Default Re: (si2die4)
Yes, I run an oil dist block too, but you have to tap the oil from somewhere... I never said it was tee'd at the block. Does the easy out tool require drilling? I am not familiar with this tool...
Old Oct 18, 2004 | 08:14 AM
i my honda
Global Mod
Default Re: (maxspeedhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxspeedhonda &raquo;</TD></TR><TR><TD CLASS="quote">Yes, I run an oil dist block too, but you have to tap the oil from somewhere... I never said it was tee'd at the block. Does the easy out tool require drilling? I am not familiar with this tool...</TD></TR></TABLE>
No it does not! Did you use an NPT fitting?
Old Oct 18, 2004 | 08:17 AM
PrecisionH23a's Avatar
The ez-out looks like a drill bit/punch. You hammer it into the broken fitting, then simply unscrew it. It works, trust me. Just be careful.
Old Oct 18, 2004 | 12:02 PM
12 oz.'s Avatar
Default Re: (PrecisionH23a)
use ez out same exact thing happen to me
good luck
Old Oct 18, 2004 | 07:41 PM
Default Re: (12 oz.)
Damn I can't believe I have never heard of this tool. Where did you all get yours? Would Sears definatley have it (before I drive all the way over there)?
Old Oct 20, 2004 | 03:01 PM
Anyone know what size ez-out tool I will need to purchase to do this. The auto-parts guy told me that he has them in several different sizes.
Old Oct 20, 2004 | 03:42 PM
Turbo E's Avatar
its a broken bolt extractor, for lack of a better term
hammer it in then twist with a wrench. the more you turn the harder it bites into whatever you're removing.
Old Oct 20, 2004 | 04:19 PM
richeybrooks's Avatar
Default Re: (Turbo E 604)
would you just go and get one. allready
Old Oct 20, 2004 | 06:07 PM
Default Re: (richeybrooks)
yeah, but I asking WHAT SIZE!!!!! They make about 30 different ones.
Str8fourvtec
Mar 22, 2010 07:48 PM
almostboostedgsr
Feb 7, 2007 01:35 PM
Mr HYDE
Jul 9, 2005 05:04 PM
ntegls
Dec 28, 2003 10:26 AM
simike
Sep 12, 2002 01:28 PM
