need some advice with b16a2 power up
Old 10-18-2004, 02:08 PM
fastsmurf04's Avatar
Default need some advice with b16a2 power up
which would be the better set up, jackson racing supercharger or turbo bolt on kit? if i do the turbo kit do i need to build the motor? ive heard the compression is to high i need some advice!! please help!!
Old 10-18-2004, 02:11 PM
_gurusan_'s Avatar
Default Re: need some advice with b16a2 power up (fastsmurf04)
What are your goals?
The JRSC will give you great daily driving torque...gives power where the b16 has NONE whatsoever.....(below 3000)...but it has less peak HP....
You don't have to build your engine for a turbo...(again depending on your goals)....you just need to tune it well for it to be reliable...
The turbo will provide you with a LOT of peak HP and a lot of torque..but you will have some lag depending on which turbo you choose
Old 10-18-2004, 02:12 PM
Default Re: need some advice with b16a2 power up (_gurusan_)
i just want something reliable, and something that is a sleeper, i only plan on using a t3/t4 but just some basic bolt on things.
Old 10-18-2004, 02:17 PM
11psiTurboSI's Avatar
Do it right the first time.... TURBO
Old 10-18-2004, 02:39 PM
Default Re: need some advice with b16a2 power up (9psiTurboSI)
come on guys help!!! im looking!!
GEN2 LS
08-29-2012 02:51 PM
Midwest_Ridaz
10-08-2009 09:22 PM
1baddcivicsi
10-11-2006 10:09 PM
Evil_Wizard
07-24-2003 06:23 AM
LOwrestling2001
11-11-2002 07:30 AM
Quick Reply: need some advice with b16a2 power up
