boost controller and BOV
Old Oct 17, 2004 | 09:52 PM
ktran1's Avatar
Default boost controller and BOV
Hi,
I can see that with AVCR and Profec B, it is possible to have two setup (usually A (for low boost 8 psi for ex. ) and B (for high boost 12 psi for ex.) )
If I set two boost like that, is there no problem with BOV because it is possible to set only under one boost ?
thans for your replies
Old Oct 18, 2004 | 11:59 AM
RyanEJ8's Avatar
Default Re: boost controller and BOV (ktran1)
The boost controller settings should have no effect on the BOV at all. The BOV reads vacuum seperately.
Old Oct 18, 2004 | 01:02 PM
tgreaves's Avatar
Default Re: boost controller and BOV (RyanCivic2000)
The size of the BOV has to do with the amount of boost being ran.. But for the 2 different amounts of boost you want to run then your fine with your BOV set the same for both..
Old Oct 18, 2004 | 01:05 PM
MooreBoost's Avatar
Default Re: boost controller and BOV (tgreaves)
Just run a TurboXS dual stage boost controller.
Old Oct 18, 2004 | 01:06 PM
tgreaves's Avatar
Default Re: boost controller and BOV (tegunderpressure)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegunderpressure &raquo;</TD></TR><TR><TD CLASS="quote">Just run a TurboXS dual stage boost controller.</TD></TR></TABLE>
Why???
Old Oct 18, 2004 | 01:10 PM
MooreBoost's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">
Why???</TD></TR></TABLE>
Why not?
Its cheaper, it works, much less wiring, it does exactly what he wants. KISS- keep it simple, stupid.
Old Oct 18, 2004 | 01:11 PM
tgreaves's Avatar
Why not?
Its cheaper, it works, much less wiring, it does exactly what he wants. KISS- keep it simple, stupid.</TD></TR></TABLE>
I just figured that maybe your were saying running this boost controller would answer his question about needing his BOV set at 2 different settings..
Old Oct 18, 2004 | 01:16 PM
MooreBoost's Avatar
Ohh, no, I didnt mean that.
I dont think he should have a problem with that. The BOV opens from the vacuum it see's, not from the pressure surge on the valve. Its going to see that vacuum regardless of the boost he runs.
Old Oct 18, 2004 | 01:22 PM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegunderpressure &raquo;</TD></TR><TR><TD CLASS="quote">Ohh, no, I didnt mean that.
I dont think he should have a problem with that. The BOV opens from the vacuum it see's, not from the pressure surge on the valve. Its going to see that vacuum regardless of the boost he runs.</TD></TR></TABLE>
Gotcha.. I figured you were just suggesting a different boost controller for him though.. I dont think I have ever seen the turboxs boost controller before, Ill have to look into that..
Old Oct 18, 2004 | 01:29 PM
MooreBoost's Avatar
http://www.turboxs.com/ManualB...shtml
Im going to run one.
accordturb96
Sep 20, 2015 03:37 PM
jBj
Mar 14, 2005 10:37 AM
brickonwheels
Feb 19, 2004 02:42 PM
TurBoXBirD16
Feb 10, 2002 10:20 AM
