Is my BOV Broken?
Old Oct 18, 2004 | 08:14 PM
Blkteg97's Avatar
Default Is my BOV Broken?
I have a 97 integra LS A couple of months ago when I first finished my Turbo Project I Went to drive it and I had a Blown Turbo (long Story) so I took it off and I had oil residue all in my charge pipe and everywhere. So after I got my turbo rebuilt I put it on and it works great but now my HKS bov deosn't sound like it should well it deon't sound like my friends eclipse who has the same one. Instead of a Wistle its more of a weird chirping sound. and it deosn't even start to chirp until like 6psi before that it just sounds like the blits bov. at first I though that it was because my turbo was aftermaket so it would sounds diferent than stockturbo cars with HKS bov's but than I was thinking that somehow oil got into my bov and jacked it up. So if anyone could give me some advice, or let me know how there integra sounds with a HKS BOV. Thanks sorry this is so long
Old Oct 18, 2004 | 08:26 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Is my BOV Broken? (Blkteg97)
You answered your own question. Oil has been sucked into your BOV which is causing it to sound differently. I, too, have an HKS SSQV...however the sound of it changes depending on the amount of boost. At 4-10psi -- stock HKS high pitch sound ~ 11psi+ -- two tone lower pitch sound.
Old Oct 19, 2004 | 06:30 AM
PrettyLude's Avatar
yeah the sound varies with the amount of boost pressure
Old Oct 19, 2004 | 08:13 PM
Blkteg97's Avatar
Default Re: (PrettyLude)
Well I took it apart and there is no oil in it, could it possibly be not enough vacuum. Im getting a Vacuum manifold tomoroow so ill see if that will help. Thanks
Old Oct 19, 2004 | 09:36 PM
SiKid86's Avatar
Default Re: (Blkteg97)
my friend actually punctured the diaphram on his some how.. and it fucked his BOV up.. You check that for any little tears or what not?
Old Oct 21, 2004 | 07:00 PM
Blkteg97's Avatar
Default Re: (SiKid86)
I took it for a drive today, and I have some mad Comprssor surge! I don't know whats wrong with it. Im taking it to a guy who fiwed his bov with the same problem so ill see what happens. anymore suggestions?
Old Oct 21, 2004 | 08:40 PM
Blkteg97's Avatar
I was thinking of just going to the Turboxs RFL anybody had experiance with this bov, Since I am only running 9psi will this bov work good on my setup? ive head its for higher boost aplications is this true? Thanks
Old Oct 21, 2004 | 10:20 PM
ojoemamao4o's Avatar
have a turboxs rfl 4 sale...pm me
Old Oct 21, 2004 | 11:02 PM
Street Ghost's Avatar
Default Re: (ojoemamao4o)
Have you tried adjusting that screw and nut on the BOV to see if it makes any difference?
pcguy760
Aug 18, 2008 09:08 PM
buttsneeze
Mar 17, 2005 11:07 PM
Snafu-Si
Jun 3, 2004 10:32 AM
Generation2
Jul 29, 2003 10:41 PM
