wastegate not clearing hood, help
alright this is a d16, have an SFP log manifold, and tial 38mm wg, when i close my hood the thing that screws on the top of the wastegate hits my hood, it is a CF hood so im thinking will cutting it be the only option? or would i be able to have a pipe welded to my flange and run to my wg and mount it sideways?
Re: wastegate not clearing hood, help (VtecAdil)
Cutting would be your only option if you want to keep it on top of the manifold. (what chassis is this?) Otherwise, your idea of an extension would work too.
How much space do you think you'll need? You can try the "washer" trick and raise the rear of the hood a 1/2 inch and hopefully clear the wastegate up front? Worth a try given your circumstance.
i ♥ my honda
Global Mod
Global Mod
This is a very common problem
You need a 90deg. elbow, revhard kits come with one or you can find one here used for like 35-40$ Ya, I know its outrageously priced
Re: wastegate not clearing hood, help (si2die4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si2die4 »</TD></TR><TR><TD CLASS="quote">This is a very common problem
Like Si2die4 said. Get the elbow. I think importparts.com actually has them for like 35 bucks new. Not sure. Contact ben at importparts. He is a good guy
alright thanks guys, but would i need to get another flange or should i just take the one off the manifold, and just weld the pipe straight to the manifold or get another flange?
