Getting New Motor need advicce
Old Oct 18, 2004 | 06:25 PM
PreludeSiTdriver's Avatar
Default Getting New Motor need advicce
I am getting a new motor since I dont wanna blow the h22 i have now. I am getting a built h22 for about 5600.
New Crower PRO-billet connecting rods
New JE Forged aluminum pistons
New Honda Bearings and thrust washers.
NEW Prodrive billet oil pump
NEW ARP main and head studs, washers and nuts.
Crankshaft is micropolished and checked for out-of-round, straightness and journal sizing then balanced . Oil clearances are 0.0022" on the main journals and are 0.0018" on the rod journals.
8 New Crower exhaust stainless valves 0.5 mm oversize
8 New Crower intake stainless valves 0.5 mm oversize
New valve stem seals (high temperature on the exhaust)
New Crower titanium retainers
New Skunk2 cams gears
complete Laminar flow bench developed cylinder head work.
very mild port shaping, blend and massage the valve pockets...Intake finish is appropriate to its purpose....the exhaust pockets get mildly ported , and blended....polished exhaust ports available extra.
New Cometic head gasket
New Honda Gaskets and seals throughout.
New Greddy max performance timing belt, and new Honda water pump
correct air/fuel ratio will produce a minimum of 400 HP @ 15 psi of boost on 91 octane fuel
With this i need a good clutch kit. Can anyone recomend a good clutch? I need to hold over 350 ft lbs of torque thanks
1sikhatch
Nov 23, 2011 08:19 AM
DoNEliZ
May 8, 2008 12:10 PM
B20VTI
May 25, 2006 10:29 PM
B18C5civic
Mar 14, 2006 10:46 AM
B pwr
Feb 10, 2002 08:11 AM
