CAR PROBLEM.. LOOK
Old Oct 14, 2004 | 02:06 PM
afrothunda713's Avatar
Default CAR PROBLEM.. LOOK
I just boosted my car.... And it is running slow... sothen i decided to run the car when it is not boosting 0 psi..... and when i hit 4-5 rpms... u hear a loud noise.. like the v tech is kicking in but real louder. and stop pulling and runs slow... I have a b18c integra... like i would 0-60 in 10 secs.. its that slow... i was thinking my valve clearance or timing is off. leeme kno any ideas.... or if u ned anymore information
Old Oct 14, 2004 | 02:08 PM
mattEG's Avatar
A better description written in english would help..
Why would you keep driving when you hear a "loud noise"?
Is the loud noise detonation??
Old Oct 14, 2004 | 02:20 PM
Default Re: CAR PROBLEM.. LOOK (afrothunda713)
nah its not detonation. hard to explain. sound like your vtec kicking in. but it is a lot louder. and the noise comes before vtec even kicks in.
Old Oct 14, 2004 | 02:44 PM
ChillOutWayne's Avatar
low on vtec fluid
Old Oct 14, 2004 | 02:53 PM
Muckman's Avatar
Moderator in Chief
my guess is its not tuned at all.
go vtech
Old Oct 14, 2004 | 03:53 PM
crispydee's Avatar
Default Re: CAR PROBLEM.. LOOK (ChillOutWayne)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChillOutWayne &raquo;</TD></TR><TR><TD CLASS="quote">low on vtec fluid</TD></TR></TABLE>
Please dont forget that for best performance and engine protection you should use JDM vtec fluid
Old Oct 14, 2004 | 11:27 PM
what do you mean vtec fluid
Old Oct 15, 2004 | 10:00 AM
ANY OTHER SUGGESTIONS
Old Oct 15, 2004 | 10:33 AM
Muckman's Avatar
Moderator in Chief
dude you havent give us any details about your setup. What are you using for fuel management? Are you tuned? Is your vtec fluid full?
Old Oct 15, 2004 | 10:52 AM
yellowturbo's Avatar
probably a unplugged hose or a defective clamp if you have no boost at all...
Old Oct 15, 2004 | 11:00 AM
Default Re: CAR PROBLEM.. LOOK (crispydee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crispydee &raquo;</TD></TR><TR><TD CLASS="quote">
Please dont forget that for best performance and engine protection you should use JDM vtec fluid </TD></TR></TABLE>
damn, cant believe i forget to mention that, JDM for life
until i get my lightning of course
Old Oct 15, 2004 | 12:10 PM
UtahRockabilly's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by afrothunda713 &raquo;</TD></TR><TR><TD CLASS="quote">what do you mean vtec fluid</TD></TR></TABLE>
you don't know about vtec fluid!!!!!
Oh man you need to get some or your car will never run right!
Old Oct 15, 2004 | 12:38 PM
Default Re: CAR PROBLEM.. LOOK (UtahRockabilly)
OK.I have a 95 GSR I have a 42 48 t3 turbo 60 trim. MY car seems real slow. I am boosting 7 psi. slow spoolin in 1st and 2nd gear.... so i jus took off my wastegate so i can only boost 0 psi... when i run the car at about 4500 rpms.. u hear noise like vtec kicking in but it is louders... and the car stop pulling hard... my fuel management is fmu until i get my ecu chipped for uberdata... still doing.. MY car will rev up hard till 4500 rpms.. then slowly go to 8,000... doesnt pull anymore and this is at 0 psi.... let me know if you need more information. P.S. Anybody in Jersey or NY or close tune a car with uberdata... let me know
Old Oct 15, 2004 | 12:44 PM
nonvtecD's Avatar
People are making fun of you because you spelled vtec with an H in your first post Then you asked about vtec fluid as if it was a real thing Vtec on GSR's engages at 4400 RPM at WOT stock, so... Any exhaust leaks that wouldnt allow your turbo to spool? Any IC piping leaks? Your boost gauge is telling you you're running 7 psi? There has to be a leak somewhere for the car to "feel slow" at 7 psi, I mean FMUs suck too but...
Old Oct 15, 2004 | 01:22 PM
5l-eater's Avatar
It sounds like ur cam timing is way off according to that sound
Old Oct 15, 2004 | 01:48 PM
Default Re: CAR PROBLEM.. LOOK (CRXdan1.6)
how do i find out if my cam timing is off.
Old Oct 15, 2004 | 05:13 PM
nonvtecD's Avatar
If he never removed his head his cam timing wouldn't just go off. Did you read what I said? Stock GSR vtec is at 4400 RPM. You said this noise hits before vtec at 4500 RPM, impossible.
Old Oct 15, 2004 | 05:20 PM
Default Re: (D15B7turbo)
MY timing skipped like 2 or 3 teeth last year. so i just relaigned it... now i am bout to recheck my cams.
Old Oct 16, 2004 | 01:59 PM
Default Re: (afrothunda713)
My cam gears look like it is off like a half a teeth.. I took pictures but dont know how to post it. How do i post my pictures.
Old Oct 17, 2004 | 01:05 AM
iiilgsrlll's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by afrothunda713 &raquo;</TD></TR><TR><TD CLASS="quote">so i jus took off my wastegate ....</TD></TR></TABLE>
Umm....did you physically pull it off the manifold?
If you did that's why its so loud. LOL.
Old Oct 17, 2004 | 02:19 AM
jessemarCc's Avatar
Default Re: CAR PROBLEM.. LOOK (iiilgsrlll)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iiilgsrlll &raquo;</TD></TR><TR><TD CLASS="quote">
werd.
Old Oct 17, 2004 | 07:41 AM
Default Re: CAR PROBLEM.. LOOK (bluracer)
pull what off the manifold?
Old Oct 17, 2004 | 07:48 AM
djwest24's Avatar
i guess it's an internal wastegate.
Modified by quicksilver17981 at 5:10 PM 10/17/2004
Old Oct 17, 2004 | 08:17 AM
Default Re: CAR PROBLEM.. LOOK (quicksilver17981)
yea in internal
Old Oct 17, 2004 | 09:10 AM
Sohc Driver's Avatar
Im sorry man...I think you should take off your turbo kit and do a little more research. You have very little knowledege in regards to boost. Don't take this the wrong way, but do it before you regret it.
Khoi
