What should i do?
Old Oct 17, 2004 | 08:30 AM
greyrex's Avatar
Default What should i do?
Hie bros!I'd just fixed up my jrsc on my crx ef8 but the rpm during idling is quite high at 4500rpm.What is the cause of this and what should i do?I dare not even drive the car yet as the idling is really high...Thanks.
Old Oct 17, 2004 | 09:38 AM
PrettyLude's Avatar
check the throttle cable or iacv
Old Oct 17, 2004 | 10:08 AM
Oyvind Ryeng's Avatar
Could also be a vacuum leak in the intake. Did you quadruple-check all the vacuum lines? Are they all hooked up right?
Old Oct 18, 2004 | 04:35 AM
greyrex's Avatar
Default Re: (Oyvind Ryeng)
Thanks for the info but looks like everything is doing fine.I think i've got to give up on supercharging my rex.Will try to double check again.Thanks.
Old Oct 19, 2004 | 04:57 AM
greyrex's Avatar
Would there be any problem with the tps sensor that is on the throttle body?I did changed into dc2 throttle body but for the tps sensor,i used back my original b16a1 as the dc2 throttle body doesn't come with a tps sensor?Would that be the cause of high rpm in my engine?Thanks.
Old Oct 19, 2004 | 05:10 AM
Adi Radoncic's Avatar
On Fire!
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">check the throttle cable</TD></TR></TABLE> could be the tps but I doubt it, the rpms wouldn't be that high if it was the iacv, tps, fast idle valve, vacum leak. but maybe you have a freak on your hands.
Old Oct 19, 2004 | 05:30 AM
greyrex's Avatar
Default Re: (newgsr)
I can't fix my original b16a1 throttle body into the jrsc as my fast idle valve casing is separated from the throttle body unlike the itr or other b series throttle body which the fast idle valve casing is joint with the throttle body.I guess i've got to look for the itr tps sensor.One more thing,could i start my car without the jrsc belt attached to the alternator?Thanks.
Old Oct 22, 2004 | 02:52 AM
greyrex's Avatar
Could i get my rex running without the jrsc belt attached to the alternator?Thanks.
TonyRomo
Apr 30, 2009 07:06 PM
19_hatch_93
Nov 23, 2008 07:08 PM
damn_import_culture
Jul 13, 2006 08:06 AM
frostcivic
Oct 12, 2004 03:52 AM
HATCHFREEK
Jun 13, 2003 12:47 PM
