need help boost creep
Old Oct 14, 2004 | 12:59 PM
cutt's Avatar
Default need help boost creep
I have a d16z6 built bottom end with lowered compression 8.5:1 . using a t3t4 60 trim with an internal waste gate and turbonetics boost controller, spearco intercooler, 2.5 inch down pipe 2.25 test pipe 2.5 inch cat back and greddy E manage. when tuning on the dyno yesterday the more we tuned and added fuel the hire the boost climbed. Wanting 10 psi with this set up . kept climbing we stopped at 14 psi with mbc all the way off . With out the boost controller it holds at 5psi all the way to redline. Thank in advance
Old Oct 14, 2004 | 01:13 PM
ChrisRicketts's Avatar
Default Re: need help boost creep (cutt)
if it holds 5 psi to redline without creeping, then maybe you have an issue with your controller.
Old Oct 14, 2004 | 01:47 PM
cutt's Avatar
Default Re: need help boost creep (ChrisRicketts)
tried same model but a buddies controller and had same problems
Old Oct 14, 2004 | 02:05 PM
XxRoCkMaNxNEOxX's Avatar
try getting another controller. try another standard boost controller or the DIY 4 dollar one.
Old Oct 14, 2004 | 02:49 PM
cutt's Avatar
Default Re: need help boost creep (XxRoCkMaNxNEOxX)
how do you make one A web sit with good instructions would be great thanks. Could it also be to far away about 2-3 feet
Old Oct 14, 2004 | 07:30 PM
cutt's Avatar
bump!
Old Oct 15, 2004 | 11:15 AM
cutt's Avatar
any one else
Old Oct 15, 2004 | 12:04 PM
SSBPGSR's Avatar
http://www.geocities.com/chmwatson/FAQs/mbc.html
there you go
Old Oct 15, 2004 | 12:11 PM
Rory Breaker's Avatar
Default Re: need help boost creep (SSBPGSR)
What boost controller are you using? Creep is common with poorly designed controllers, and if youre not creeping running off the WG, theres your problem.
ochsy03
Mar 24, 2005 08:53 AM
civicshowracing65
Feb 11, 2003 04:21 AM
smoothludey2
Feb 25, 2002 02:39 PM
_Shadow_
Nov 23, 2001 11:16 AM
