turbo kit question(s)
Old Oct 16, 2004 | 12:44 PM
BUCKO5's Avatar
Default turbo kit question(s)
A buddy of mine is getting this kit, and wants to know if when he gets it, can he just bolt it straight up to his b16 del sol, with the stock fuel/ecu/managment for a few weeks until he can get his hondata and injectors? i have a vortec fmu in the garage, think its a 12:1 but not sure at all, do we need to use that?
New Turbonetics T3/T4 Turbocharger A/R of .48 T04E compressor
3.00" inlet and 2.00" outlet.
Billet 35mm wastegate
Front Mount Intercooler Polished!
2.5" Inlet/Outlet - High Flow!
Dimensions 30.00" X 9.00" X 3.00"
Intercooler piping - 304 *No Rust* Stainless Steel
Nitrile Elbows, Silicone Hoses, clamps etc.
Stainless Turbo Header Polished!
Quality Tubular style manifold made of 304 stainless steel
T3 standard flange. Will fit all civic b-series engines
Turbo intake/filter
3.00" Inlcudes 1 Polished aluminum intake tubing
3.00" 1 Silicone couplings
3.00" 1 Performance Air Filter
Oil Supply and Drain Kit
3.00 '-3AN stainless steel oil supply
1-5/8" x 16.00" high temp oil return
Oil Drain Flange
Stainless Steel Downpipes
2.00" Stainless steel down pipes (Weld to fit ANY setup)
External Wastegate Block-off Flange
Old Oct 16, 2004 | 09:19 PM
PrettyLude's Avatar
in the drag kits or any other kit for the b series, they use a 10:1 ratio fmu. the 12:1 ratio fmu is not enough fuel
Old Oct 17, 2004 | 07:04 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: turbo kit question(s) (BUCKO5)
If your buddy is eventually going to get bigger injectors and Hondata in a few weeks.... why don't he just hold up on the turbo install until then. That's what I would do if it was my car. Just my opinion....... Oh yeah...by the way. How on earth did you even get a LS turbocharged Del Sol to only run low 14s. I did that on my hatch (LS swap with ACT clutch on 13" donuts)..... all motor stock!!!
Old Oct 17, 2004 | 08:59 PM
BUCKO5's Avatar
Default Re: turbo kit question(s) (NVturbo)
that was on 18 inch cp-10s at only 6 psi...and a 2.4 60'...and the del is a heavy bitch...2690 with me and a 1/2 tank (i weigh about 120)
i am trying to convince him to just get the injectors/hondata while he is waiting for a good weekend to put it on, that way he can have it the way he wants it right off the bat....
Old Oct 17, 2004 | 09:09 PM
toolowsol's Avatar
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">in the drag kits or any other kit for the b series, they use a 10:1 ratio fmu. the 12:1 ratio fmu is not enough fuel</TD></TR></TABLE>
12:1 provides MORE fuel than 10:1...
And yes you will need ATLEAST a FMU, but why not just wait until the hondata comes in?
Old Oct 17, 2004 | 09:53 PM
solunderpressure's Avatar
Default Re: (toolowsol)
thanks for the help guys but im just gonna get the hondata, and the injectors now so i can just have it all done in one install instead of waiting and all that jazz. if anyone has any other advice, maybe on oil pan tapping methods, for a newbie turbo guy, lemme know.
IN VTEC
Mar 28, 2008 12:33 PM
Live*JDM
Dec 1, 2007 02:05 AM
nsh1351
Nov 17, 2005 09:42 AM
97-P72
Jun 2, 2005 06:24 PM
Short Round
Nov 10, 2003 03:19 PM
