Intercooler CFM efficiency
Old Oct 18, 2004 | 09:35 AM
MooreBoost's Avatar
Default Intercooler CFM efficiency
When I had a guy mount my IC and fab up the charge pipes he cut the endtanks off the side and relocated them to the back. Is that going to hurt how well the IC flows? With normal mounting, the air can flow straight through the IC and use the nice smooth bends of the piping to make its 90 degree turns, now its a very abrubt turn.
Old Oct 18, 2004 | 11:29 AM
MooreBoost's Avatar
Default Re: Intercooler CFM efficiency (tegunderpressure)
I have been told it will effect spool time.
Old Oct 18, 2004 | 01:26 PM
MooreBoost's Avatar
Another person agree's that it is too sharp of an angle. Anyone here want to comment?
Old Oct 18, 2004 | 06:28 PM
MooreBoost's Avatar
Old Oct 18, 2004 | 06:42 PM
tubegown's Avatar
Two sides of the story.
If the end tanks are facing your engine, most likely your charge pipes are significantly shorter. Which is obviously a plus because the chance of pressure drop or temperature of the air in the charge pipes dropping will lower.
The flip side is the flow with be more abrupt and not as smooth causing some extra turbulance.
Which is better?
I doubt either or will cause really noticible differences.
Old Oct 18, 2004 | 06:45 PM
MooreBoost's Avatar
Default Re: (tubegown)
I never thought about the shorter piping. Thanks.
Old Oct 22, 2004 | 04:10 PM
MooreBoost's Avatar
Default Re: (tegunderpressure)
Old Oct 22, 2004 | 05:41 PM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
Show me some pics and I'll give you an opinion.
Old Oct 22, 2004 | 05:51 PM
MooreBoost's Avatar
Default Re: (tjbizzo)
Its like this.
Modified by tegunderpressure at 4:01 AM 10/23/2004
Old Oct 22, 2004 | 06:25 PM
Mag00n's Avatar
looks fine to me.
Old Oct 23, 2004 | 09:36 AM
MooreBoost's Avatar
Default Re: (Mag00n)
I thought about it and I think Ill just spray like a 30 shot to it, it will cost just as much as a new FMIC and piping and will really be beneficial once I build it.
Old Oct 23, 2004 | 09:41 AM
MidShipCivic's Avatar
The shorter piping isn't really significant enough to be an advantage.
blackeg
Jul 31, 2012 04:37 AM
g_man1968
Jan 23, 2006 02:55 PM
88crxhfb16
Sep 25, 2005 06:59 PM
buck02
Jul 5, 2004 11:43 AM
asianspeed
Jan 16, 2003 06:42 PM
