???Sleeving???
Old Oct 16, 2004 | 02:01 PM
2.2motore's Avatar
Default ???Sleeving???
Im looking into starting my new turbo setup for next season and im dealing with the motor first. So here is my question, i want to sleeve a block and i have a choice from three blocks to pick, B16a,B18b, or b18c1 witch would preform best when handleing the 400-600 horse power range and witch would the best sleeves to use and were do i get it done.
Thanks
Danny
Old Oct 16, 2004 | 02:07 PM
Boostage's Avatar
Default Re: ???Sleeving??? (Tec1)
no offense man, but do you know what it takes to build a 600hp honda? if you are not sure about sleeves, then you might not.
Old Oct 16, 2004 | 02:31 PM
93LSivic's Avatar
GSR block hands down. It utilizes a girdle.
ERL for sleeving. Not the cheapest, but the best money you can spend on sleeving, period.
Old Oct 16, 2004 | 05:27 PM
WREKONIZE V8 KLR's Avatar
b16 and give me the other two....
Old Oct 16, 2004 | 05:34 PM
ExospeedAMcrx's Avatar
Default Re: (WREKONIZE V8 KLR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WREKONIZE V8 KLR &raquo;</TD></TR><TR><TD CLASS="quote">b16 and give me the other two....</TD></TR></TABLE>
LOL.
All of those blocks will handle the power you want to make. Its a matter of the right combination of parts to make that kind of HP.
Theres plenty of factors that will determine how efficient your setup will be. here's a picture of a sleeved B16. Theres advantages and disadvantages of using b16 and a b18 block. B16s usually have less torque than b18 blocks. We prefer b18s for max power but b16a block can make 400-600 no problem.
Another thing to consider is compression. Most turbo setups are in the low compression, about 9:1 to 10:1. But you can choose to do a higher compression turbo setup if you want. We've done 11:1 turbo setups and the pistons are still flat top and good for forced induction.
You just need to plan more in detail so you can determine what is best for you.
Old Oct 16, 2004 | 06:50 PM
BEEYOND's Avatar
Default Re: ???Sleeving??? (Threatcon13)
ERL is good.....Bang for the buck EXOSPEED...good ****!!!
Old Oct 16, 2004 | 06:56 PM
Default Re: ???Sleeving??? (nicholashang87)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicholashang87 &raquo;</TD></TR><TR><TD CLASS="quote">ERL is good.....Bang for the buck EXOSPEED...good ****!!! </TD></TR></TABLE>
Gracias.
Goldmember: 9 sec Integra: Exospeed Race Block
Group Tenacity: 600+ HP: Complete Exospeed Race Engine
Courtney Green: Street Car 10.20s, Exospeed Blocks 700+HP
Irran Jolly: Hot Rod CRX, 700+HP Exospeed Race Engine
Exospeed CRX: D16A6 All Motor 190whp Exospeed Block
Old Oct 16, 2004 | 08:06 PM
2.2motore's Avatar
so how much am i looking at to sleeve a B series motor?
Old Oct 16, 2004 | 08:07 PM
PrettyLude's Avatar
around a 1000
Old Oct 16, 2004 | 08:14 PM
Default Re: (Tec1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tec1 &raquo;</TD></TR><TR><TD CLASS="quote">so how much am i looking at to sleeve a B series motor?</TD></TR></TABLE>
We charge $880 and that includes the Bore, Hone, Hot tank, and Step Deck.
Old Oct 17, 2004 | 04:49 AM
Boostage's Avatar
Default Re: (exospeedAMcrx)
[QUOTE=exospeedAMcrx]
We charge $880 and that includes the Bore, Hone, Hot tank, and Step Deck.[/QUOTE
lifetime warranty?
Old Oct 17, 2004 | 11:52 AM
Default Re: (Boostage)
its warrantied for anything related to the sleeve installation process itself.
Old Oct 17, 2004 | 12:39 PM
ATS*Mark's Avatar
OG triple OG
you guys use RS sleeves or dartons?
Old Oct 17, 2004 | 11:27 PM
Default Re: (Hella_JDM)
we have our own cut sleeves that we use. RS Machine was using our sleeves.
We use Dartons on certain blocks such as some H-series and D-series.
Old Oct 26, 2004 | 11:39 AM
2.2motore's Avatar
what hind of sleeves do you use
Old Oct 28, 2004 | 02:59 PM
Default Re: (Tec1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tec1 &raquo;</TD></TR><TR><TD CLASS="quote">what hind of sleeves do you use</TD></TR></TABLE>
Darton or our own.
D_koschak
Sep 22, 2008 02:55 PM
thizzledance
Dec 11, 2006 06:36 AM
pythoner
13
Oct 28, 2006 11:18 AM
jdm b18c ek4
17
Sep 5, 2006 10:38 AM
92SiBlu
20
Feb 27, 2006 05:30 PM
