Radiator install during turbo install
Old Oct 18, 2004 | 02:43 PM
XxRoCkMaNxNEOxX's Avatar
Default Radiator install during turbo install
i am doin my turbo setup and i came to the part that i had to take off the fan that is hooked up to the radiator. the prob. was that the upper radiator hose was in the way. i took off the radiator hose and it started leaking a little. took off the fan and reinstalled the upper radiator hose will the radiator be fine? i opened the cap and it looks like it lost a little. should i put some coolant in there. will i have any bubbles or sumthing like that?
Old Oct 18, 2004 | 04:02 PM
Default Re: Radiator install during turbo install (XxRoCkMaNxNEOxX)
ne help?
Old Oct 18, 2004 | 05:24 PM
PrettyLude's Avatar
yeah you should refill it, and remember to bleed the system
Old Oct 18, 2004 | 06:01 PM
Default Re: (PrettyLude)
how do i bleed the system?
Old Oct 18, 2004 | 06:57 PM
djwest24's Avatar
Default Re: (XxRoCkMaNxNEOxX)
the easiest way is to open the radiator cap (when its cold, obviously) start your car and let it come up to normal operating temp. u'll start seeing bubbles come up. let it all come out, might take about 5 mins or so, in the meantime keep topping it up with coolant. do it till the bubbles are out, put on the cap, and ur good to go.
Old Oct 18, 2004 | 07:46 PM
Default Re: (quicksilver17981)
thanks man
Old Oct 21, 2004 | 11:12 AM
Slow_Em1's Avatar
i just fill it, works fine with me, also i use only distilled water...no coolant
water has better cooling properties
Old Oct 21, 2004 | 01:11 PM
Default Re: (TodaFiend)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TodaFiend &raquo;</TD></TR><TR><TD CLASS="quote">i just fill it, works fine with me, also i use only distilled water...no coolant
water has better cooling properties</TD></TR></TABLE>
just water eh.
Old Oct 21, 2004 | 01:54 PM
4-banging's Avatar
drain it
use a mixture of 50 anitfreeze/ 50 water
turn car on and let temp rise
as rad loses water add water only
I keep my reservoir tank filled halfway with only antifreeze.
Old Oct 21, 2004 | 02:28 PM
Default Re: (4-banging)
thanks for the input so looks like every says drain it, fill it up w/ 50/50 , then leave cap open, then let it get to normal temps, then wait till bubbles calm down then turn off car and cap it off. correct?
Old Oct 21, 2004 | 08:37 PM
JeffS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XxRoCkMaNxNEOxX &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the input so looks like every says drain it, fill it up w/ 50/50 , then leave cap open, then let it get to normal temps, then wait till bubbles calm down then turn off car and cap it off. correct?</TD></TR></TABLE>
The Helms will tell you to run it until the fan comes on and off twice. Longer won't hurt, but you need to make sure all the air is out of the system.
Old Oct 21, 2004 | 09:31 PM
BremertonDA's Avatar
From: Bremerton, Washington, United States of America
You wouldn't want to just use water, antifreeze has agents that help keep the hoses clean and keeps them from crapping out.
Old Oct 21, 2004 | 10:31 PM
Slow_Em1's Avatar
Default Re: (BremertonDA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BremertonDA &raquo;</TD></TR><TR><TD CLASS="quote">You wouldn't want to just use water, antifreeze has agents that help keep the hoses clean and keeps them from crapping out.</TD></TR></TABLE>yea, but for a quick fix til the next week when you get paid, it works just fine. also the water pump could rust out.
Dm914
Jun 25, 2015 05:31 PM
lmike6453
Oct 14, 2008 02:03 PM
halo2k7
17
Jul 23, 2008 09:57 PM
Spec R
Jun 15, 2006 02:29 PM
94gsr_vtc
12
Jul 26, 2004 08:23 AM
