JRSC FUEL HELP...
Old Oct 17, 2004 | 07:08 AM
Honda_RN's Avatar
Default JRSC FUEL HELP...
Heres my setup first:
GSR with a 6 PSI JRSC
SRT Intake with Apexi filter
JR upgrade fuel pump (Walboro one)
Colder NGK plugs
JR boost timing controller
Stock headers/ exhaust
I had it dynoed tuned again recently but stilll having issues with the A/F ratio being around 13.5 : 1 ... I know I need to be around 12:1 but what can I do right now to make that happend???
I was thinking of upgrading my injectors to some bigger ones but I am a bit confuse on saturated ..etc.... so which injectors should I get for my application?
Secondly I am planning to get a Cartech FMU ..... let me know what you guys think .. thx
Old Oct 17, 2004 | 08:13 AM
Honda_RN's Avatar
Default Re: JRSC FUEL HELP... (Ringbearer020)
bump for a dude in need of help
Old Oct 17, 2004 | 10:23 AM
Honda_RN's Avatar
bump bump
Old Oct 17, 2004 | 12:21 PM
Tad's Avatar
Tad
errr, how did you have it dyno tuned ?
what kind of fuel management are you running?
you cant "TUNE" an fmu, it pumps in a certain ammount of fuel per lb of boost it sees.
you need to get yourself some bigger injectors,
then an a/f controller of some sort.
Old Oct 17, 2004 | 01:17 PM
Honda_RN's Avatar
Default Re: (Tad)
so would a Vortech FMU or cartech fmu help?
Old Oct 17, 2004 | 01:26 PM
Tad's Avatar
Tad
Default Re: (Ringbearer020)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ringbearer020 &raquo;</TD></TR><TR><TD CLASS="quote">so would a Vortech FMU or cartech fmu help?</TD></TR></TABLE>
dude they're all fmu's
you can get one with a higher rated disk and it'll pump more fuel in there.
but I wouldnt waste my money on getting ANOTHER fmu,
get some real fuel managemetn.
Old Oct 17, 2004 | 01:48 PM
hypa's Avatar
Default Re: (Tad)
I agree with Tad.
An FMU is an easy way to change fuel rates, but the bottom line is that it's a static change. You change it for a lean condition at 4500rpm, and it richens up everything. Get yourself into Uberdata, or AEM, or Hondata (buy from the same shop that tunes!!!!!), and that will help a lot.
For injectors, Hondas like saturated injectors (low impedance). Some have had luck with DSM low impedance 450's, but I never did. RC is your best bet for a replacement set. Go with a 440 saturated if you want to run 12+psi, and a 370 if you want to run less than 10psi.
Other than that, if you want a cheap/easy way to bump your fuel, go with a B&M fuel pressure regulator and increase your static fuel pressure a few psi. Be sure to keep an eye on your plugs though, or else you could be too rich.
JDC2TypeR
Aug 25, 2007 11:32 AM
bonylad
Oct 5, 2006 10:40 AM
creechrr
Dec 9, 2004 02:03 PM
Green Lude 93
Sep 20, 2004 12:56 PM
