Too many problems.. smoking, weird noises
Old Oct 18, 2004 | 07:16 PM
ICeDoUt's Avatar
Default Too many problems.. smoking, weird noises
ok lets start off.
1. i installed gsr cams into my b16 crx, without adjusting valves.
2. i hooked up zdyne standalone without any tune, i jsut grabed a basemap offline somewhere. <-- i know its the dumbest thing to do.
3. Went for a ride, then the problems......
Went for a hard pull, and after that pull i heard a ting ting ting. i got back to my house, smoke was everywhere, it looked white, popped the hood.... my cam gear seal was popped out, oil all over the front of my block, i pushed it back in. Wait till the mornign to mess with it, start it up, Light blue smoke out my exhaust and a little smoke coming from behind my block. Its like coming up under the intake manifold. (i think its cause of my pcv valve, i think a catch can would solve that problem). Then i rip off my intercooler piping to find some oil in there, and oil is in my downpipe. Did a compression check on a hot motor and it was like it was before. Then my someone esle did a compression check on a cold motor, and the numbers were all fucked up
So i ripped the head off tonight, found nothing wrong with the cylinder walls, or the piston tops. only thing i found that was wierd was that one piston was slightly lower then the rest. But by like 1/8th of an inch. and that was the cylinder that was messed up with compression. once the head was off, i poured water over the valves to see if they held water (to check if they were bent) and they held water. Is that even a way to check if they are bent? But yea, i dunno what to do now, i am guessin i need rings, and a catch can to get rid of all my blow by. anyone else with thoughts? and/or people to tell me how dumb i am for running an untuned car?
Old Oct 19, 2004 | 04:19 AM
ICeDoUt's Avatar
Default Re: Too many problems.. smoking, weird noises (ICeDoUt)
anyone, with any help?
Old Oct 19, 2004 | 07:04 AM
underpressure02's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ICeDoUt &raquo;</TD></TR><TR><TD CLASS="quote">ok lets start off.
anyone else with thoughts? and/or people to tell me how dumb i am for running an untuned car?</TD></TR></TABLE>
Well since I am your friend and helped your rip out another motor this weekend your a dumbass for boosting on it without a tune.
Did you get a chance to pull the oil pan off yet? Could be a bent rod that is why the piston is lower.
How do the cylinder walls look? Can you still see the x hatching? Or is it really smooth like the motor we pulled?
Help this kid out.
Old Oct 19, 2004 | 08:56 AM
ICeDoUt's Avatar
Default Re: Too many problems.. smoking, weird noises (underpressure02)
well i didn't see ****, but then my dad looked at it. He says he can still see cross hatching marks, and that cyliner #2 has a little scuff in it.
Oil pan comes off today after i eat
Old Oct 19, 2004 | 01:26 PM
ICeDoUt's Avatar
update: I got a bent rod/ cracked ringlands after taking the pistons out, sooooo waht should i do, replace with stock parts, or upgrade
Old Oct 20, 2004 | 09:19 PM
alleyezonme's Avatar
upgrade you jackass!! thats not even a question!! especially since you wanna crank up the boost.
Old Oct 20, 2004 | 09:27 PM
DOHCarp's Avatar
Time to upgrade!!!!!!
Old Oct 21, 2004 | 04:58 AM
ICeDoUt's Avatar
Default Re: Too many problems.. smoking, weird noises (DOHCarp)
thinking just replacing with stock shiat to get it running again, then build up my b18, cause right now i have little to no money, i prolly coulnd't even afford 1 aftermarket piston
Old Oct 21, 2004 | 04:59 AM
Come on vince be a man. Just put that rod in the vice straighten it out and put some jb weld on it for added support.
Old Oct 21, 2004 | 05:03 AM
ICeDoUt's Avatar
This is true JB weld is the solution to all of my problems
j-bird20
Jan 11, 2007 05:59 PM
mattL
Oct 28, 2003 07:40 AM
Spike2
Jul 6, 2003 03:05 PM
shermanyang
Aug 5, 2002 05:11 PM
GruvyTune
May 24, 2002 11:10 AM
