help with greddy kit
Old Oct 18, 2004 | 08:28 AM
90teg's Avatar
Default help with greddy kit
hey I just installed a greddy turbo kit on a 95 civic ex.
The car has a full msd ignition,hollowed out cat,b7m press. reg., aem fuel rail,
and of couse the turbo kit.
whenever I start to really hit the boost around 4000 rpm's or so the car goes lean.
I know that I prob need bigger injectors and better fuel tuning my question is, whether this is a common problem or not?
Did I miss something saying that I should be getting bigger injectors??
thanks
Old Oct 18, 2004 | 08:34 AM
mattEG's Avatar
Bigger injectors would definately help out the situation. As would fuel management such as uberdata or hondata so that you could better tune your timing/fuel/ignition whatever.
Lets just put it this way, whatever you do if you are running lean at boost you're going to break something so fix it.
Old Oct 19, 2004 | 06:37 AM
PrettyLude's Avatar
also a good fuel pump would do
Old Oct 19, 2004 | 06:48 AM
BauleyCivic's Avatar
Risky Business
Default Re: (PrettyLude)
FMU's rock!
Look at getting a warlboro 255 inline fuel pump first and seeing what that does.
Are you running any boost timing retard?
JDM turbo DC
Nov 8, 2005 05:51 PM
red_hatchback
Sep 7, 2005 04:39 AM
95EXcivicsleeper
Apr 22, 2004 12:03 AM
epmugenlude
Mar 27, 2004 05:56 PM
crxnug
Jan 30, 2002 05:46 PM
