Oil from breather?
Old Oct 16, 2004 | 09:40 PM
BoostedJeff's Avatar
Default Oil from breather?
Recently I have noticed that there is a small amount of oil on my breather filter, and a little bit on the 3rd and 4th runner of my intake manifold. It is obvious that it is coming from the breather on the valve cover, I would just like to know what could case this. And just to let you know, this motor is heavily boosted.
Thanks
EDIT: Also, the motor only has 2,000 on the new build
Old Oct 16, 2004 | 11:06 PM
Boltz's Avatar
Default Re: Oil from breather? (JDMHatch4Me)
maybe the crankcase pressure is too high and you need a catch can
or
maybe you have blowby
Old Oct 17, 2004 | 05:26 AM
StolenTeg's Avatar
Default Re: Oil from breather? (Boltz)
Most likely it blowby, there also a chance your ring might be going too. Check the compression and it should show up...
Old Oct 17, 2004 | 05:30 AM
Boosted2K's Avatar
or
Old Oct 17, 2004 | 06:14 AM
USDM 4G VTEC's Avatar
its the pressure on the crank case
if u have aliminated the PCV system, since theres no more vacum from the intake, the blowby increases
i have good compression numbers'
and i get a lot of blowby
thats why i went and got a catch can
Old Oct 17, 2004 | 09:32 AM
RyanEJ8's Avatar
I don't think the blowby will increase because there is no vacuum on the PCV from the intake. Even the Endyn catch can (off-road) setup does not hook up to vacuum on the intake manifold.
Old Oct 17, 2004 | 11:33 AM
Quad-Damag's Avatar
Default Re: (RyanCivic2000)
u might of put 2 much oil in, when u did your oil change as well and it's trying to vent out the extra.
Old Oct 17, 2004 | 05:57 PM
endlesswinterco's Avatar
Default Re: (Quad-Damge)
jeff, you need to get a catch can like mine, problem solved.
Old Oct 17, 2004 | 11:07 PM
Default Re: (RidinlowHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RidinlowHatch &raquo;</TD></TR><TR><TD CLASS="quote">jeff, you need to get a catch can like mine, problem solved.</TD></TR></TABLE>
ben, that is what I am hearing, I just get kinda worried, being how paranoid i am about my car. I just want to make sure everything is ok internal wise!
What does it mean if my compression is perfect, but it is still happening?
I am sure a catchcan is the answer....just want to make sure
Old Oct 18, 2004 | 08:12 AM
RyanEJ8's Avatar
Default Re: (JDMHatch4Me)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMHatch4Me &raquo;</TD></TR><TR><TD CLASS="quote">
Catch can is not going to solve the problem. The only difference that will happen is instead of having to wipe up the extra oil off the manifold every now and then you're going to have to dump out your catch can. Oil is still going to come out. It's supposed to. That means it's working.
Looneytunerz
Nov 2, 2012 12:57 PM
dc2milanoking75
Apr 8, 2009 10:12 AM
rob[CB7]
May 22, 2008 12:59 PM
PinkMaggit
11
Jan 6, 2007 04:18 PM
