pcv question (yes I searched)
Old Oct 15, 2004 | 07:11 AM
maxspeedhonda's Avatar
Default pcv question (yes I searched)
Ok, I have specific questions for you guys. Keep in mind that this car will never be driven on the street so emissions is not an issue (will not use pcv). I just bought the endyn breather kit and I am going to install it per the included instructions. Please see if anyone could answer some of my questions below:
1. What do you do with the stock vac line coming off the back of the block? I know you are supposed to put a freeze plug into the large port where the stock seperator was, but what about the small line running out of the block?
2. My stock valve cover breather plus the two additional ones I added need to be routed somewhere. Can I just run hoses from theses down to the ground open loop?
3. What size allen head are the two plugs on the back of the block? I also need the honda part# for the freeze plug.
Your help is greatly appreciated.
Old Oct 15, 2004 | 07:58 AM
turbosi03's Avatar
Default Re: pcv question (maxspeedhonda)
the allen heads are 14mm... thats all I can help you with... I need to do the same thing your doing.
Old Oct 15, 2004 | 08:19 AM
Boosted2K's Avatar
Default Re: pcv question (turbosi03)
The endyne setup will come with another screw-in fitting for the port that the hose comes out of, above the black box.
Just put a cheap breather filter on the valvecover.
unhook the hose on the intake manifold and cap it with a vacuum cap.
14mm hex, I found on at autozone. $8.00
Be sure to use some hondabond or RTV on the supplied freeze plug
Old Oct 15, 2004 | 05:10 PM
Default Re: pcv question (Boosted2K)
I have three breather openings on my valve cover including the oem one. Will it be okay to vent all three of them to the atmosphere via hoses pointed at the ground at the rear bottom of the block?
Old Oct 16, 2004 | 04:43 AM
ttt
likuidphreon
Feb 4, 2013 06:12 AM
HandMadeEgRHd
May 8, 2010 06:29 PM
incubusboy87
Aug 13, 2007 09:02 PM
