oil presure guage problem
Old Jan 24, 2005 | 09:26 AM
dAng! Kris's Avatar
Default oil presure guage problem
i have a defi oil pressure guage and I can't figure out whats wrong with it. I dont get any oil pressure lights at all and everything runs normal. But my oil pressure doesnt go past about 55-58psi when at WOT up in the rpms. And at idle its either zero or bounces from 0-5psi. I have everything set up right I just cant figure it out.
BTW the car is a turbo GSR
Old Jan 24, 2005 | 09:28 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: oil presure guage problem (Frozty)
have youchecked the oil pump and the pickup? Also, where are you pulling your reference for oil pressure?
Old Jan 24, 2005 | 10:12 AM
dAng! Kris's Avatar
Default Re: oil presure guage problem (wantboost)
using reference from my buddy this is his old kit on my car
Old Jan 24, 2005 | 10:15 AM
wantboost's Avatar
Who is Mr Robot?
maybe i worded that wrong, where is the pressure sender for your oil pressure gauge?
Old Jan 24, 2005 | 10:35 AM
dAng! Kris's Avatar
its coming off the back of the block to a T on the firewall for my oem sending unit from there it T's again for the guage then it goes to the turbo
Old Jan 24, 2005 | 10:37 AM
wantboost's Avatar
Who is Mr Robot?
try to get ahold of a guage that you know works, and compare them, if the readings are still of, then i would check the oil pump and pickup
Old Jan 24, 2005 | 11:23 AM
AzG35's Avatar
I had the same problem. I had a -3an to a tee to my oil pressure gauge sender, stock sender, and oil feed line and had the same readings as you. I upgraded the line to the tee with a -4an and left the -3an to the turbo and the oil pressure is rock solid now, 15-20 at idle and 70-80 at full pressure by 4k rpms.
Old Jan 24, 2005 | 12:19 PM
Sohc Driver's Avatar
Default Re: oil presure guage problem (AzSi22)
Definitely go buy a cheap mechanical oil pressure guage from Autozone or Oreilly's and hook it up to compare the oil pressure readings.
Khoi
Old Jan 24, 2005 | 12:38 PM
93turbo16's Avatar
yea, that is really something you don't want to mess with or take a chance on.
maglites94
May 29, 2012 10:56 AM
hotshot100
Apr 14, 2010 05:10 PM
swlabhot
Aug 4, 2005 06:10 AM
vtec.dc2
Feb 1, 2004 10:49 AM
vtecsiqt
Jun 17, 2002 07:51 PM
