Help o2 sensor placement
Old Jan 22, 2005 | 08:35 AM
ebpcivicsi1234's Avatar
Default Help o2 sensor placement
I dont have my camera so i cant take a pic..But i put my primary o2 sensor at the end of my downpipe which my 3 in adaptor goes over.So what i did is i drilled a hole in the adaptor and then the downpipe have the bung welded on and now the o2 sensor alony sticks out like1/2 in at the most in the exhaust iam i going to get inaccurat readings because its not stick out far enough
Old Jan 22, 2005 | 08:40 AM
93turbo16's Avatar
if you welded the bung on correctly it should be just fine.
Old Jan 22, 2005 | 08:47 AM
Default Re: (93turbo16)
what do u mean by correctly id say its more like 1/4 in stick out
Old Jan 22, 2005 | 08:49 AM
93turbo16's Avatar
what kind of bung did you get? If it is welded flush, then it shouldn't be a problem. But 1/4 sounds kinda short.
Old Jan 22, 2005 | 08:55 AM
ya i think iam just going to have to redo it my situation is my down pipe comes out with a 3 in with no flanges or anything..Iam not running a cat so i need something to connect to my 3 in down pipe then to connect to my 2 1/2 in 3 bolt flange for my apexi exhaust any ideas
jarven93
Nov 21, 2009 11:09 PM
Pman92
Apr 18, 2007 06:46 AM
leonard1818
Nov 29, 2004 09:05 AM
djnikko
Aug 13, 2004 09:34 AM
BanEL
Nov 22, 2003 12:26 PM
