what numbers to expect, LS-VT
Old Jan 22, 2005 | 06:59 AM
projectPSI's Avatar
Default what numbers to expect, LS-VT
B18b1 Block
Eagle rods
JE 9:1 pistons.
LS Trans
B16a2 Head (stock)
Garret gt28rs turbo
hks Cast Iron - Turbo Exhaust Manifold (17141-139387)
hks ssqv
jhonnyracecar 6in intercooler
thermal r&d 3in catback turbo exhaust, thermal high flow cat.
rc 550cc injectors
walbro 255 fuel pump
act hdss clutch kit
AEM EMS
Custom DP, Custom Intercooler Piping
What hp numbers would i most likely come out with around 10-12 lbs of boost.
Old Jan 22, 2005 | 07:27 AM
Rod.'s Avatar
Default Re: what numbers to expect, LS-VT (projectPSI)
It is hard to say. I have a sc61 ls-vt and 8psi made 300. I forgot the other numbers cause I was having so many problems which are fixed now. I need to re dyno one day.
I will tell you one thing right now ditch that Ls transmission. Get a b16 or Gsr. Night and day difference from ls to gsr.
Old Jan 22, 2005 | 09:42 AM
projectPSI's Avatar
Default Re: what numbers to expect, LS-VT (redturbocivic)
how high could i rev with that setup? The head will stay stock for a while but will be upgraded with cams, springs, and retainers in teh near future.
would lets say 300 whp with like a 8000 rpm redline be a safe, reliable goal on the stock head and stock sleeves and other parts listed. I understand tuning is key.
The rotating assembly withh be balanced.
Old Jan 23, 2005 | 09:54 AM
projectPSI's Avatar
Old Jan 23, 2005 | 11:18 AM
Rod.'s Avatar
Default Re: (projectPSI)
i go to 8400 no problem. I have gsr cams springs & retainers. I might be able to go higher who knows.
Old Jan 23, 2005 | 11:21 AM
Rod.'s Avatar
Default Re: (redturbocivic)
You would have to get it on the dyno to see how high you can rev...only way i see it
Old Jan 23, 2005 | 11:56 AM
projectPSI's Avatar
what pistons you running?
Old Jan 23, 2005 | 12:37 PM
Rod.'s Avatar
cp
Old Jan 26, 2005 | 05:18 AM
projectPSI's Avatar
b16 or b18 vtec head? you used ls spec pistons tho right?
Old Jan 29, 2005 | 09:37 AM
projectPSI's Avatar
would it be a bad idea to run my ls-vtec prepped for turbo, (pistons, possibly turbo cams) without the turbo on? I want to build teh motor, run it for a while and then save up a bit of cash and do the turbo setup. What are the disadvantages of doing this? Will i be losing a lot fo power? What numbers shouldl i expect on a non turbo ls/vtec prepped for turbo.
Old Jan 29, 2005 | 03:36 PM
JdmEKCivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectPSI &raquo;</TD></TR><TR><TD CLASS="quote">would it be a bad idea to run my ls-vtec prepped for turbo, (pistons, possibly turbo cams) without the turbo on? I want to build teh motor, run it for a while and then save up a bit of cash and do the turbo setup. What are the disadvantages of doing this? Will i be losing a lot fo power? What numbers shouldl i expect on a non turbo ls/vtec prepped for turbo. </TD></TR></TABLE>
The #'s wont be that great since your runing such a low c/r. But you shouldn't have any problems, just make sure you tune it for allmotor then retune it for turbo.
TravisBiggie
Aug 23, 2013 04:55 AM
JConto
Sep 6, 2012 04:23 PM
Gold DA9
Nov 15, 2011 04:26 AM
TurboTegB18c
Jan 21, 2005 05:04 AM
Rocks
Oct 12, 2004 06:28 PM
