building engine in cold weather ? >>
haha nice. i wish it was 10 here. -3 hurts when you hold on to the Tq wrench...
Personally I would build it in the living room. if you're doing it right there shouldn't be much mess.
how the hell do you get a fully bult motor out of the living room after you have it built.
im not putting a engine lift in my living room. haha.
i would love to do that though.
platinum.
platinum.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">how the hell do you get a fully bult motor out of the living room after you have it built</TD></TR></TABLE>
A full long block ins't that heavy. 2 normal size person will carry it with no problem. I have done it before
Adriano
Adriano
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">I assumed your girlfriend was huge....sorry
so if i get a huge girlfriend, it makes then engine lift fit ?
platinum.
platinum.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">A full long block ins't that heavy. 2 normal size person will carry it with no problem. I have done it before</TD></TR></TABLE>
your prolly correct. i still dont want to build it inside my house. it's semi-nice.
so building in the cold is not recommend then or what .
platinum.
platinum.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brryder »</TD></TR><TR><TD CLASS="quote">
Adriano</TD></TR></TABLE>
Thats what I did, well my friend is like 115lbs, hes a lil bitch, so I did most of the work. lol
BTW, I have mine sitting on an engine stand in my laundry room. Along with all my other spare car ****, tires etc. . . .
Bolts become slightly more brittle in the extreme cold.
Also, tolerances will definitely be slightly different.
Whether or not this will have an effect on your build, i cant say.
I will say however, that the aluminum door at my store expands when it gets cold.
So much in fact, that it sticks open and wont close. It usually has about 1mm of clearance around it when its summer time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 »</TD></TR><TR><TD CLASS="quote">umm. laundry room is not a bad idea.
i dont care about doing it in the cold, if it does not affect the build.
platinum.</TD></TR></TABLE>
Yup, build it on the $100 stand, then rent a lift for one day, get a friend to help carry it out to the lift, then drop it in. Orrr just buy a $300 cycle of test, and carry it outside yourself
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 »</TD></TR><TR><TD CLASS="quote">how the hell do you get a fully bult motor out of the living room after you have it built.
Ask Vtec69
Ask Vtec69
yea im worried about the metal expanding or not expanding due to the cold.
i dont really care about myself getting cold. that's what they make beer and liqure for.
platinum.
platinum.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 »</TD></TR><TR><TD CLASS="quote">yea im worried about the metal expanding or not expanding due to the cold.
id be more worried about building an engine on beer and liquor than in th4e cold
i drink way to much,
so a couple to keep me warm will be fine.
so should i start building this damn thing or what.
it looks so pretty, i want it in the car.
platinum.
I would not build an engine outside in cold like that. I don't know how much, but cold temperatures will affect the tolerances in the motor. What is a good tolerance cold might turn out to be way too loose when it gets to be 70 degrees outside. Build the motor inside where it's nice and warm, or wait till spring.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 »</TD></TR><TR><TD CLASS="quote">so if i build in in the spring when its warm.
then when it gets cold wont the tolerance be to tight.
platinum
The tolerances listed in the helms manual, etc are set around a standard temperature, which is probably around 75 fahrenheit. When the motor is cold those tolerances are going to be closer, but that's why you let the motor warm up before driving it hard. If you build the motor cold and set the tolerances cold they're going to open up too much when it gets warm and **** can go wrong.
platinum
sounds good.
the motor is already built, i just need assemble the following :
put the head on block.
intake manifold
clutch and flywheel
oil pump, water pump, etc...
platinum
intake manifold
clutch and flywheel
platinum
Well, the metal should actually shrink when its cold. In the case of our door at work, i think its more a case of the door frame shrinking, and the door itself "swelling" from the heat inside.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 »</TD></TR><TR><TD CLASS="quote">sounds good.
intake manifold
clutch and flywheel
platinum</TD></TR></TABLE>
Oh. I thought you were talking about taking a bare block and assembling it. You should be fine with that stuff, but it's the piston to wall gap, ring gap, bearing clearances, etc, that I wouldn't do in cold weather.
intake manifold
clutch and flywheel
yea, thats why i clarified. it looked like you guys might be talking about that.
so it's ok to put my arp's in and torque the head down to 70 lbs.
i also think my buddy has a heater i will make him let me barrow that will help out a bit.
platinum.
platinum.
