MOTOR ?
Old Jan 24, 2005 | 07:53 AM
974drgs's Avatar
Default MOTOR ?
I CAN HAVE 3 MOTORS TO CHOOSE FROM B16 2ND GEN., B18B, B20B. I HAVE ABOUT $900 TO WORK WITH. B16 IS $600, LS $500, B20 $550 FOR LONG BLOCKS. I ALSO HAVE A 99 SI THAT THE MOTOR WILL GO IN. MY B16 IS TRASHED. I HAVE A DRAG TURBO KIT TO GO ON THE MOTOR. WHICH WOULD BE BETTER TO USE? I CAN'T SLEEVE IT OR DO A LS/VTEC, B20VTEC SWAP NOT IN THE BUDGET. IT WILL BE AS IS. SO WHICH ENGINE WILL BE THE BEST TO USE ?
Old Jan 24, 2005 | 07:55 AM
underpressure02's Avatar
Default Re: MOTOR ? (b16blacksi99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16blacksi99 &raquo;</TD></TR><TR><TD CLASS="quote"> I CAN HAVE 3 MOTORS TO CHOOSE FROM B16 2ND GEN., B18B, B20B. I HAVE ABOUT $900 TO WORK WITH. B16 IS $600, LS $500, B20 $550 FOR LONG BLOCKS. I ALSO HAVE A 99 SI THAT THE MOTOR WILL GO IN. MY B16 IS TRASHED. I HAVE A DRAG TURBO KIT TO GO ON THE MOTOR. WHICH WOULD BE BETTER TO USE? I CAN'T SLEEVE IT OR DO A LS/VTEC, B20VTEC SWAP NOT IN THE BUDGET. IT WILL BE AS IS. SO WHICH ENGINE WILL BE THE BEST TO USE ?</TD></TR></TABLE>
WHAT I CAN"T HEAR YOU????
SEARCH
Old Jan 24, 2005 | 08:15 AM
PrettyLude's Avatar
LS, turn off your caps
BlueFizZ
30
Jul 16, 2009 09:31 AM
c0j0nes
11
Jun 5, 2009 07:15 PM
HondaTeKnology
54
Jan 4, 2008 08:16 PM
974drgs
Jan 23, 2005 06:22 PM
DRAG14ciVHBKSI
Aug 8, 2002 11:00 AM
