carburetor fuel manage :P
1 Post
Re: carburetor fuel manage :P (@lbert)
On our RX1 kits, we put the carburator on the suck-side of the turbo. As long as you have a turbo with Carbon bearings(for blowing air AND fuel), everything is pretty much just like an NA motor, as the carb only sees vacuum.
yep, that is called a drawthrough system, you just need carbon seals in the turbo, to keep from spewing oil all over the place. It is a very simple design, but you can't run an intercooler with it, that is the only down fall. BUt you could get away with just running water or alch injection to make up for it.
lothian
11-08-2018 02:04 AM
