Dart Block Boring and Honing
Old Jan 23, 2005 | 09:02 AM
IMPORTant Si's Avatar
Default Dart Block Boring and Honing
I have a Dart Block that has to be bored and honed to 84.5mm. There is only one place around here that has a bore/hone small enough. Thing is, he doesn't have a torque plate to bolt down while doing the work. He explained to me that any block will distort about .003" - .005" no matter what you do. I'm planning to push 500+ whp with this block and I don't need anything screwing up. Is he right about the distortion? What should I do?
-James
Old Jan 23, 2005 | 10:48 AM
HXMan's Avatar
Default Re: Dart Block Boring and Honing (IMPORTant Si)
bump for you.
Old Jan 23, 2005 | 01:12 PM
donkiman's Avatar
i dont know where u are from but dart just opened up a new shop in indiana.
Old Jan 23, 2005 | 02:35 PM
_entropy's Avatar
If your local shop doesn't even have a torque plate, I wouldn't have them put the motor together for you. Look into shipping it somewhere.
Old Jan 23, 2005 | 02:47 PM
earl's Avatar
You do NOT need a torque plate to bore/hone a Dart block or any OEM B block. The head bolt holes in the block of a Honda are placed so as to not distort the independent sleeves. Most domestic blocks and some Toyota and Nissan blocks do require deck plates but not the Honda. It all has to do with the placement of the bolts in the block in relation to where the sleeves are located.
eg:R
Apr 19, 2014 08:56 AM
Rickcrx
Feb 23, 2012 05:18 PM
ERL Performance
Performance
10
Dec 16, 2010 05:41 PM
aakeobo
Jan 26, 2006 07:31 PM
