Is this Tial wg a 38mm?
I bought this wg used and was taking it apart to polish the housing and have the body coated. I have seen people selling 35mm Tial's and was curious if mine was a 35 or 38mm. I took some pics to explain and so hopefully someone can clear this up.
All dissasembled:
The gasket that was used measures at 38mm
Flange where dumptube connects
Flange where it meets manifold
With the ring removed from the flange
All dissasembled:
Re: Is this Tial wg a 38mm? (oxSLEEPERxo)
Actually thats what I am going to do. I am gonna port the opening and the exit to 38mm and polish the inside and piston head. Going for max efficiency.
Re: Is this Tial wg a 38mm? (TURBODC4TEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TURBODC4TEG »</TD></TR><TR><TD CLASS="quote">looks like a ssautochrome wastegate and 35mm with maybe a 38 top?</TD></TR></TABLE>
it's for sure a ssautochrome no tial casting on the cover
Who is Mr Robot?
Re: Is this Tial wg a 38mm? (tremor86)
yea, you can see the tial on the casting for the vlave body. people dont even know what a dman tial looks like, sad.
In-N-Out Burger
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quad-Damge »</TD></TR><TR><TD CLASS="quote">
it's for sure a ssautochrome no tial casting on the cover</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tremor86 »</TD></TR><TR><TD CLASS="quote">It definately isnt a ssauto. it says tial right on the top and is cast into the body.</TD></TR></TABLE>
pWned
pWned
its a 35MM.
one is the top is different. its a one 45 and then straight down. instead of "wavy" like most 38s
also 38';s have a bellmouth chamber at the bottom. kinda flared out like a tulip.
Re: Is this Tial wg a 38mm? (project dc2)
thanks. I am having mine ported as we speak. When done, it will probally actually outflow a regular 38mm. Ill keep ya posted
Re: Is this Tial wg a 38mm? (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost »</TD></TR><TR><TD CLASS="quote">yea, you can see the tial on the casting for the vlave body. people dont even know what a dman tial looks like, sad.</TD></TR></TABLE>
your right i could barely see the tial on the casting
Re: Is this Tial wg a 38mm? (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r »</TD></TR><TR><TD CLASS="quote">Wait guys, I don't think he understood, is it a 35mm or 38mm? </TD></TR></TABLE>
Its is 35mm, but he is going to port his to a 38mm
hah... ill post pics when it is done. The end of the piston kind of has a ridge to it so im going to smooth that out and polish the end and the shaft. Also, im porting the inlet and outlet to 39mm and deburring the inside of the body.
accordfreak
08-29-2003 03:39 AM
