stupid question time! Yaaay --Turbo to mani, WG to mani gasket Questions...
I read somewhere while searching that you dont need a gasket from the turbo to the manifold, or in between the WG and manifold. Some tool was saying he never used then and they are not necessary... Funny cuz the head to mani has one.
What you guys run? Who sells gaskets if needed?
Re: stupid question time! Yaaay --Turbo to mani, WG to mani gasket Questions... (Ls1 FD3s)
use a metel gasket from the engine to turbo manifold, but for the wastegate u don't need a gasket they will all just leak, just tightin it real good and you will be fine.
i dont run a gasket between my mani and wastegate and i've had no problems. i used the tial gasket for about 2 weeks before it blew.
Re: stupid question time! Yaaay --Turbo to mani, WG to mani gasket Questions... (Quad-Damge)
i am using gaskets at both those areas. i got a gasket set from kragen from i think an old turbo thunderbird.
i also had a problem with the gasket blowing at the wg to mani area. the problem was the bolt attaching the pressure line was too big and it hit the valve cover making the wg not seat properly. i shaved it down a bit and never had a problem since.
Re: stupid question time! Yaaay --Turbo to mani, WG to mani gasket Questions... (GSRrR)
Im running a full-race mani, garret t3/t4, tial 40mm WG, and 4 bolt 3" DP flange. Any honda-tech vendors sell the proper gaskets for my setup?
thanks
-james
thanks
-james
hoya_10fintec
12-24-2005 10:37 PM
