afc hack
Old Jan 21, 2005 | 11:09 PM
ramennoodles's Avatar
Default afc hack
does anybody know the proper way to set up the afc "hack", I got an afc from awhile back and wanna try it out. done some researching and some saying it has a bad timing curve, some say they wire throttle wire to map wire, some say they like and some say it fuc*ed up motor.
Old Jan 22, 2005 | 06:47 AM
Default Re: afc hack (600gixxer)
Old Jan 22, 2005 | 07:20 AM
93turbo16's Avatar
https://honda-tech.com/zerothread?id=841443
Old Jan 22, 2005 | 07:21 AM
The Destroyer's Avatar
Read that buddy boyee.
Old Jan 22, 2005 | 07:25 AM
93turbo16's Avatar
man, that was interesting ^ look above.. haha.
Old Jan 22, 2005 | 07:31 AM
Default Re: (93turbo16)
Haha yeah, if I didnt type anything we prob would have been at the same time.
Old Jan 22, 2005 | 08:20 AM
93turbo16's Avatar
agreed.
Old Jan 22, 2005 | 02:39 PM
yes, i've read that before, showing the ignition curve. what I want to know is numbers used on the afc. more interested on the wiring the tps wire to the map wire method. some sites stated people using that set-up, but they didn't explain the settings of the afc. thanks for the link though
Old Jan 22, 2005 | 04:34 PM
93turbo16's Avatar
sounds retarded. Go some other route if you don't feel comfortable doing it.
Sorry to say.
Old Jan 22, 2005 | 04:53 PM
rjardy's Avatar
I agree, if its not something that you feel you can teach yourself or feel comfortable you really shouldnt bother with it. there is also way better and cheaper ways to correctly manage your fuel.
Rob
Old Jan 22, 2005 | 05:37 PM
Default Re: (rjardy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjardy &raquo;</TD></TR><TR><TD CLASS="quote">I agree, if its not something that you feel you can teach yourself or feel comfortable you really shouldnt bother with it. there is also way better and cheaper ways to correctly manage your fuel.
Rob</TD></TR></TABLE>
Exactly, I find uberdata alot more easy to learn.
Old Jan 22, 2005 | 10:12 PM
Default Re: (Vtaaak y0)
I already had an afc just lying around so I though I would put it to use. maybe I'll just sell it to somebody
Old Jan 22, 2005 | 10:20 PM
Tchleung's Avatar
Just wire it up and correct however much you need via wideband, and boost as much as your stock map sensor can take, retard distributor 2-3 degrees and you should be "okay" Running as much boost your map can take will bring you clsoer to the proper IGN timing tables. about 1-2 degrees off.
hotimportcrx
Nov 1, 2005 07:19 AM
love2xlr8integra
Aug 7, 2005 03:55 PM
Ski11z
Jul 15, 2004 08:36 AM
This One
Feb 2, 2003 04:20 AM
