New Distributor, Now Real Lean?!?
Old Jan 24, 2005 | 07:59 PM
Tchleung's Avatar
Default New Distributor, Now Real Lean?!?
So over the winter, my distributor took a dump on me one morning when I went to start the car. Whatever, so I put a new distributor on the other day, set my timing to 16 and new plugs as well. after a day of driving and boosting, I check how my new plugs are doing. they are LEAN! Okay what the heck.
I have not changed my tune at all.
Timing is at 16
Plugs are gapped to .30 like my old plugs.
My old plugs were ALWAYS a very nice, overly rich look.. (lol) I don't see what's wrong now and how I am running lean.. ANy suggestions? I'm still running perfect 12:1 A/F. The plugs show no sign of detonation, yet... The only thing I can think of is I set my timing wrong(highly unlikely) or that my old distributor was actually retarded a lot more then 16. Here's a pic of my old plugs on the left, vs new plugs on the right. The new plugs turn white right away.
Modified by Tchleung at 11:17 AM 1/25/2005
Old Jan 24, 2005 | 08:51 PM
93turbo16's Avatar
when did you check the plugs? The same way you always do?
Old Jan 24, 2005 | 08:55 PM
Tchleung's Avatar
same as always. after I driven it and let it cool down for aobut 30 minutes
Old Jan 24, 2005 | 09:00 PM
Tchleung's Avatar
either way on my old plugs and old distributor. I chaecked it at random tiems as well. always teh same. ncie and rich. I jsut don't ge tit. ym A/F is perfectly rich. howt eh heck can my timnig be off. my distributor itself sits about center on the adjsutment range which is normal.
Tchleung's Avatar
I'm gonig to recheck my timnig again and redo it. maybe somehow I set it to 16 degrees advacned, FROM 16 so 32.. doubt it tho. I don't think the dizzy can go taht far and again. it sits neutral in the center of adjsutment.
I should also add taht my EGT's are low as well.
Modified by Tchleung at 10:22 PM 1/24/2005
Old Jan 24, 2005 | 09:27 PM
Tchleung's Avatar
UPDATE!!!!!!
I just looked on this webpage. http://www.atlanticjetsports.c...5.htm
My plugs look like the top left one which is under "Normal" Maybe Im safe and before I was overly retarded and was flooding the plugs?
ALso, I did some searching on ehre and a few people said they tend to be lean when they are new and will take af ew days to change colour. Something about enw plgus turn white fora f ew days first sicne theya re heated up for the first time... Anyone comfirm?
Modified by Tchleung at 10:40 PM 1/24/2005
Old Jan 25, 2005 | 07:45 AM
Tchleung's Avatar
TTT
Old Jan 25, 2005 | 08:56 AM
turbo*s2k's Avatar
Default Re: (Tchleung)
I think your new plugs on the right look good. They look really white in the picture, but it could be the camera. They look okay to me...
Old Jan 25, 2005 | 10:01 AM
Tchleung's Avatar
the electrode is acutalyl very white. very white.. the insulator has a tinge of brown as you can see. I'llt ry to get better pic today.
Old Jan 25, 2005 | 10:17 AM
Tchleung's Avatar
I udpated my pictures with a better focus on the lean looknig one. 3rd pic in frsit post. check it out
Old Jan 25, 2005 | 10:20 AM
sohcmasta's Avatar
whats your idle set to?
the colder whether could affect the a/f too. if you idle around 1k then retard it a few degrees, like 14ish. the plugs dont look that bad anyways...but retarded is safer than advanced.
Old Jan 25, 2005 | 10:26 AM
Tchleung's Avatar
my idle is normall 75-850. lately it's been 650 tho. kinda low but it idles and doesn't stall out. I did set my base 16 degrees timnig at 650 tho instead of 750. Anyone got pics of their plugs similar to mines? I'm jsut boggled why they are so different... These plus are new, is that person correct that I have to drive on them for a few days for the heat to chagne the colour?
Old Jan 25, 2005 | 10:39 AM
mrbsponge's Avatar
plug readin is not done off of the electrode or the arm itself mine look just like that and i am running 12:1 as well on AF. you need to look down inside the plug, there will be a raised ring, look at it with a flashlight it should be a light shade of brown....also to check them you need to do a wide open gear pull like in 3rd and when you get to the top of you rpm band shut the car off then check em, you can check em after the car idles, the timing changes from idle and WOT
Old Jan 25, 2005 | 10:43 AM
Tchleung's Avatar
thanks alot man I'll check that out. Maybe my old dizzy was jsut voerly retarded. lol
Old Jan 25, 2005 | 11:30 AM
Tchleung's Avatar
I looked down into the spark plug between the insulator and metal. all I see is black. There was a slightly tinge of brown to it tho. lol
Old Jan 25, 2005 | 11:38 AM
PM-Performance's Avatar
if they are new plugs. They look just that. . . .new. Dont look lean to me. Throw it on a wideband and find out for sure.
Old Jan 25, 2005 | 11:42 AM
Tchleung's Avatar
Default Re: (itr206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">if they are new plugs. They look just that. . . .new. Dont look lean to me. Throw it on a wideband and find out for sure. </TD></TR></TABLE>
In my first post I menitoned I do ahve a wideband which shows abotu 12:1 perfeclty fine and ncie 14.X crusing. Okay well I'm a bit mroe relieved now. hahaha. I'm just all paranoid somethnig is wrong cause a week ago I had a lot of condensation whcih lead me to think i had a head gasket, when really didn't now this so I was liek
Old Jan 25, 2005 | 11:52 AM
if the wideband says its rich and the timing is set right, then dont worry about it. New plugs take a little time to get some color to them
Old Jan 25, 2005 | 12:06 PM
Tchleung's Avatar
Great thanks
frogg5872
May 26, 2010 07:06 PM
dem0nk1d
Aug 11, 2007 12:03 PM
SLO Sol
11
Nov 16, 2005 05:51 AM
JDM00SI
Aug 15, 2005 11:26 PM
B_Love
Jul 7, 2005 09:15 PM
