DIY exhaust gasket......what can i use?
Re: DIY exhaust gasket......what can i use? (Deckedlude)
Dont use a gasket at all?
Since the turbo is flat cast and assuming the manifold flange isnt warp? Other then that, dont use one.
After numerous gasket blowing and leaking. I just decided to take them all out, and viola 5psi boost 3ooo rpm on a t3.t4..
Re: DIY exhaust gasket......what can i use? (tub_sephiroth)
you dont need a gasket the carbon build up from the tubo will seal the gaps. The only con to this is if your flang is warp you wont get a good seal, infact you will see boost leak.
Re: DIY exhaust gasket......what can i use? (JdmEKCivic)
thanks for the info guys . i was thinking that i didnt need a gasket being that there isnt one for the dp. i'll just double heck and make sure everyting is true before i put it together.
1.8T_EG
09-12-2003 07:00 PM
