I know it's not a toyota site but a friend has a MKIII supra and needs upgrade.
What is a good turbo for hte MKIII upgrade wise? He has the stocker on there still but wanted to know what the normal upgrade is? Thanks
Re: I know it's not a toyota site but a friend has a MKIII supra and needs upgrade. (dan_w_82)
tell him to look around on supraforums.com or give my old work a call http://www.mvpmotorsports.com they have quite a few guys that have mk3 supras(1 making over 550 or so on a stock block) they can help you out I am sure.
Re: I know it's not a toyota site but a friend has a MKIII supra and needs upgrade. (2000BoostedEX)
Thanks yeah he should do so but no internet. I figured I can ask here and then look for the turbo in the for sale forum.
Re: I know it's not a toyota site but a friend has a MKIII supra and needs upgrade. (m R g S r)
mkIII just stands for a generation of the car. this one referring to the 3rd generation of the toyota supra.
upgrade the stock turbo to a 60-1, a good clutch, fuel system and igniton..buddie had the setup, and ran on the afc on 26 psi..ran 12s all day on bfg drag radials. then decided to go 2jz with big turbo, and a th400 tranny..
Re: I know it's not a toyota site but a friend has a MKIII supra and needs upgrade. (eg6T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6T »</TD></TR><TR><TD CLASS="quote">he decided to go 2jz? what motor was in his supra before the 2jz?</TD></TR></TABLE>
what he said ^^^^^^
what he said ^^^^^^
Best bang for the buck upgrade (and simplest) would be to upgrade the stock CT-26... I've seen a handful of 57-trim and 60-trim upgrades push over 400WHP. My Camry was also running a 57-trim CT-26 before and it layed down 357WHP at 14 psi, and usually these turbos with the upgrade are good up to 20.
After that, it would be the usual larger injectors/pump/piggyback or standalone/turbo/manifold/clutch/etc...
Re: I know it's not a toyota site but a friend has a MKIII supra and needs upgrade. (Tony the Tiger)
yeap..my buddie went and dynoed in at 475whp with 435ft tq, on the ct26 60-1.
Re: I know it's not a toyota site but a friend has a MKIII supra and needs upgrade. (boosted_crx)
cool thanks so any 60-1 would be fine? He's getting the motor rebuilt now with some good parts and wanted a bigger turbo but I forgot to ask what size and I only see him on the weekends so it would faster to ask here.
Not any 60-1 is fine. If he has the stock manifold, his options are an upgraded ct-26 rebuild, or getting an adapter plate welded on to run a t3 or t4 turbo. CT is a weird flange that is not adaptable to other turbos. So unless he wants to swap the manifold CT upgrade is the way to go. but i hear they are sketchy.
Also i would think about a metal headgasket and ARP's before anything. they are known for killing headgaskets.
Re: I know it's not a toyota site but a friend has a MKIII supra and needs upgrade. (itr206)
a ct26 upgraded 60-1 would be fine if he plans on using it as a street driven car...but dont last long..
