Do I need head studs?
Old Jan 23, 2005 | 10:13 AM
1SlowSi's Avatar
Default Do I need head studs?
Just wondering if i would need them on my B16A2 running 14psi / 300whp. Im sure i could be safe and do it, but is it really something to worry about?
Old Jan 23, 2005 | 10:26 AM
SOHC_MShue's Avatar
Default Re: Do I need head studs? (1SlowSi)
i would get them for sure.
Old Jan 23, 2005 | 10:37 AM
93hatched_projekt's Avatar
Default Re: Do I need head studs? (SOHC_MShue)
If you got the money, it's a good buy. A thicker head gasket will drop the compression a liitle and head studs will keep the head from lifting. It's good insurance if you got the time and money.
Old Jan 23, 2005 | 11:45 AM
cnydc2's Avatar
Default Re: Do I need head studs? (93hatched_projekt)
I'd go with a set of arp studs. They are only like $120 a set from summit. You could also try a thicker head gasket but i have always just used the oem MLS head gasket and have had no problems with it. And with the ARP studs you can take your head off any time you need to and not have to worry about buying new head bolts. New studs are definatly cheap insurance
Old Jan 23, 2005 | 06:33 PM
1SlowSi's Avatar
Default Re: Do I need head studs? (cnydc2)
i dont know too much about all the actual work. But do you need to take out all the springs and valves to pull the head off? and how hard is it to put in new studs
Old Jan 24, 2005 | 08:54 AM
PrettyLude's Avatar
you can leave the springs and retainers, but you will have to change the headgasket
Old Jan 24, 2005 | 08:56 AM
racinskittle's Avatar
Default Re: (PrettyLude)
Get headstuds. They're $89shipped from "lightning" on here. You can't resue stock head bolts, but you can reuse these...which helps cost in the long run. There's no reason to pass them up.
Old Jan 24, 2005 | 09:06 AM
Burke's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SlowSi &raquo;</TD></TR><TR><TD CLASS="quote">Just wondering if i would need them on my B16A2 running 14psi / 300whp. Im sure i could be safe and do it, but is it really something to worry about?</TD></TR></TABLE>
how many miles on it. is the head off it??
if the heads off, then yes. might as well do it now
if it isnt off, then you dont need to right now. But when you blow a headgasket, i would get them then
Old Jan 24, 2005 | 10:25 AM
1SlowSi's Avatar
Default Re: Do I need head studs? (Burke)
nice questions. I have 101,000 miles on my car. yeah.. but it still runs strong. i just drove alot on the highway. The head is NOT off though thats why im thinking about all this. Its a bitch to get all that stuff off. What is the worst that can happen if i dont change them out? The head lifts and then...
OT. Are there only head studs and no head bolts? im kinda new at this.
Old Jan 24, 2005 | 11:16 AM
cnydc2's Avatar
They are headbolts stock.
Old Jan 24, 2005 | 11:25 AM
1SlowSi's Avatar
There are headbolts stock? explain.
Old Jan 24, 2005 | 11:31 AM
JRciv's Avatar
When the engine comes from the factory, there are eight bolts that go down through the head and tighten into the block. You must remove the bolts to get the head off.
With ARP hardware, there are double-threaded studs that tighten into the block when the head is removed. When you put the head on, you slip the head down over the studs and secure it by tightening eight nuts down over the ends of the studs.
Old Jan 24, 2005 | 12:45 PM
1SlowSi's Avatar
Default Re: Do I need head studs? (JRciv)
ahh i see. so instead of torqing down bolts, you are only using nuts at the top?
Old Jan 24, 2005 | 12:47 PM
JRciv's Avatar
yup
Old Jan 24, 2005 | 12:58 PM
DefiantGSR's Avatar
stock head bolts aren't reusable?
Old Jan 24, 2005 | 01:06 PM
rtype11's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JRciv &raquo;</TD></TR><TR><TD CLASS="quote">When the engine comes from the factory, there are eight bolts that go down through the head and tighten into the block. You must remove the bolts to get the head off.
With ARP hardware, there are double-threaded studs that tighten into the block when the head is removed. When you put the head on, you slip the head down over the studs and secure it by tightening eight nuts down over the ends of the studs.</TD></TR></TABLE>
just make sure you dont cheap out and buy 8 studs like JRciv, youll need 10....lol
Old Jan 24, 2005 | 01:14 PM
JRciv's Avatar
Default Re: Do I need head studs? (rtype11)
Hey, I'm not made out of money. I gots to cut some corners.
Old Jan 24, 2005 | 02:10 PM
11psiTurboSI's Avatar
Default Re: (racinskittle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racinskittle &raquo;</TD></TR><TR><TD CLASS="quote">You can't resue stock head bolts.</TD></TR></TABLE>
Negative, you can reuse oem headbolts. I reuse my oem headbolts and made 340hp with no problems.
Old Jan 24, 2005 | 03:49 PM
1SlowSi's Avatar
Default Re: (11psiTurboSI)
being that my head wont be off im gonna stick with my stock setup. What will happen if the OEM headbolts give out? Anything catastrophic?
Old Jan 24, 2005 | 03:53 PM
JRciv's Avatar
Default Re: (1SlowSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SlowSi &raquo;</TD></TR><TR><TD CLASS="quote"> What will happen if the OEM headbolts give out? Anything catastrophic?</TD></TR></TABLE>
Heh heh, yeah, think about it. Your headgasket will blow and worse, you could warp your head.
Old Jan 25, 2005 | 07:18 AM
1SlowSi's Avatar
well, how many were successful with 300whp and no problems?
B16A2
Old Jan 25, 2005 | 07:33 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SlowSi &raquo;</TD></TR><TR><TD CLASS="quote">well, how many were successful with 300whp and no problems?
B16A2</TD></TR></TABLE>
Me
Old Jan 25, 2005 | 08:09 AM
Turbo E's Avatar
Default Re: Do I need head studs? (11psiTurboSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 11psiTurboSI &raquo;</TD></TR><TR><TD CLASS="quote">
Me</TD></TR></TABLE>
I'd say you're lucky or have a gifted tuner.
Old Jan 25, 2005 | 09:21 AM
1SlowSi's Avatar
Default Re: Do I need head studs? (Turbo E 604)
You say lucky... well damn. My tuner will be Mase. I have no doubts.
Old Jan 25, 2005 | 12:11 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SlowSi &raquo;</TD></TR><TR><TD CLASS="quote">You say lucky... well damn. My tuner will be Mase. I have no doubts. </TD></TR></TABLE>
I wish Mase would come up to the midwest and tune my car too
