Question on oil pan and fitting.
Old Jan 24, 2005 | 05:20 AM
Hyaboosta's Avatar
Default Question on oil pan and fitting.
it seems that the only way to tap my oil pan would be to put the fitting in the shallow end of the pan. Is that ok to put it there? I took the oil pan off and cleaned it out and put 3 1/2 quarts of water in it to see where the oil level was and it's above. The second question is that I have to use a brass barb fitting in order for the line to fit. Is there any other way other than using hondabond or JB weld to attach the fitting to the pan?(Aluminum pan)
Old Jan 24, 2005 | 06:43 AM
m R g S r's Avatar
Default Re: Question on oil pan and fitting. (Hyaboosta)
What oil pan is aluminum? Try getting an aluminum fitting, I'm sure they make em. . . .
Old Jan 24, 2005 | 06:51 AM
Bailhatch's Avatar
Default Re: Question on oil pan and fitting. (m R g S r)
H22 pans can be Aluminum.
I have never seen an aluminum barbed fitting but with the aluminum pans there is enough material that you could drill and tap for the 1/2" pipe threads and then braze it. That would be strong a hell. or you could just drill and tap and install with JB weld to seal it. I'm sure that would work fine if that part of the pan is thick enough. And yes you can put it in the shallow end with no problems.
Old Jan 24, 2005 | 07:54 AM
Hyaboosta's Avatar
Default Re: Question on oil pan and fitting. (Bailhatch)
yeah I have never seen an Aluminum barb fitting either. The pan is from an 02 ex. I have been hearing from some people that I can braze it on but no one has confirmed it yet.
Old Jan 24, 2005 | 07:59 AM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">What oil pan is aluminum? Try getting an aluminum fitting, I'm sure they make em. . . . </TD></TR></TABLE>
My D16Y8 pan is aluminum.
Old Jan 24, 2005 | 08:13 AM
PrettyLude's Avatar
the newer h22 pans are aluminum, i wouldn't use jb weld on the oil pan, you can just braze or weld it
Old Jan 24, 2005 | 08:17 AM
aznballer's Avatar
yea i agree dont use jb weld i used it once and it leaked after time
Old Jan 24, 2005 | 08:20 AM
Hyaboosta's Avatar
Default Re: (aznballer)
but it is possible to tig weld brass to aluminum?
Old Jan 24, 2005 | 01:10 PM
Bailhatch's Avatar
Default Re: (Hyaboosta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hyaboosta &raquo;</TD></TR><TR><TD CLASS="quote">but it is possible to tig weld brass to aluminum?</TD></TR></TABLE>
no
whatever yo do dont use jb weld for any structural bond. it works fine for a thread sealant however.
Old Jan 24, 2005 | 02:21 PM
h22 civic's Avatar
Default Re: (Bailhatch)
what rod are u using to braze the aluminum?
delslow45
Apr 3, 2011 07:14 PM
Dc295kid
Nov 18, 2008 12:54 AM
Sinner
Oct 8, 2004 09:21 AM
turbochic
May 6, 2003 02:15 PM
420aNT
Mar 9, 2003 10:26 PM
