water cooled td04????
Old Jan 23, 2005 | 09:23 PM
hatchracer02's Avatar
Default water cooled td04????
i plan on using a stock wrx turbo (td04) , but the turbo has to lines for a coolant hook up. it was water cooled on the wrx, do i need to hook up coolant or do i just bypass the whole thing>?? any info would be a great .
thanks
AJ
Old Jan 23, 2005 | 10:36 PM
PrettyLude's Avatar
you can run without it
Old Jan 24, 2005 | 12:52 AM
Taikonaut's Avatar
Default Re: (PrettyLude)
Yeah you can run w/o it but as the turbo already has it and if you can I would hook it up.
Old Jan 24, 2005 | 04:23 AM
93turbo16's Avatar
Just hook it up, it takes all of 10 minutes to do. It was designed to run with water, so why not run it.
Old Jan 24, 2005 | 07:40 AM
were can i tie in to my coolant line>>>???
any ideas
thanks
AJ
Old Jan 24, 2005 | 07:55 AM
93turbo16's Avatar
I run a 16G on my and I tired off the water lines from the block, just make a loop with them. Feed goes to the feed of the turbo, and then loop the return lines back around to where you cut the line in half. Works like a charm.
Old Jan 24, 2005 | 08:14 AM
PrettyLude's Avatar
Default Re: (hatchracer02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchracer02 &raquo;</TD></TR><TR><TD CLASS="quote">were can i tie in to my coolant line&gt;&gt;&gt;???
any ideas
thanks
AJ</TD></TR></TABLE>
tb
187Chor
Jan 16, 2008 05:58 PM
purple98ek
Aug 13, 2007 10:50 PM
You_Get_Vapors
May 4, 2003 06:17 PM
soundman
Apr 22, 2003 08:27 AM
BoostedD15B7
Jan 29, 2003 12:01 AM
