Head Bolts Question?
Old Jan 25, 2005 | 10:11 AM
YiNYaNg's Avatar
Default Head Bolts Question?
Has anyone put in ARP head bolts without having to remove the head so it don't ruin the headgasket?
It's a SOHC VTEC D16Z6.
Modified by H-T at 12:13 AM 1/30/2005
Old Jan 25, 2005 | 01:00 PM
YiNYaNg's Avatar
Default Re: Head Bolts Question? (H-T)
ttt
Old Jan 26, 2005 | 12:25 PM
YiNYaNg's Avatar
bump
Old Jan 26, 2005 | 12:32 PM
beerbongskickass's Avatar
Umm, I am going to have to say no on this one (just guessing). Buy a new head gasket and do it right the first time.
Old Jan 26, 2005 | 12:41 PM
b18bturbo's Avatar
Default Re: Head Bolts Question? (beerbongskickass)
its not gonna work just replacing one stud at time you will cause the head to actually warp doing it that way. best bet buy a new gasket and do it right. Its not that difficult to do. while you at it replace the timing belt and water pump if it hasnt been replaced .
b18bturbo's Avatar
Old Jan 26, 2005 | 02:49 PM
YiNYaNg's Avatar
The current head gasket is still good. No need to replace it. I just want the asurance of the arp bolts and the higher holding torque.
Modified by H-T at 5:40 PM 1/26/2005
Old Feb 4, 2005 | 05:49 AM
Charlie Moua's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H-T &raquo;</TD></TR><TR><TD CLASS="quote">The current head gasket is still good. No need to replace it. I just want the asurance of the arp bolts and the higher holding torque.
Modified by H-T at 5:40 PM 1/26/2005</TD></TR></TABLE>
well I would certainly replace the HG when installing new arp head bolts.
The last thing you want to do is have to take of the head again, and re-torque the arp head bolts again.
keep in mind with the ARP head bolts you can only re-torque them down so many times before new ones are needed.
Thus saving yourself time & money in the long run.
Especially is this is your daily driven car cause I know how mad my wife gets when I take time away from the family to work on my car only to find out I have to redo it all over agian correctly.
charlie neng moua
Old Feb 4, 2005 | 06:10 AM
Machine1's Avatar
You should stop looking for shortcuts and do it right the first time.
You're talking about a pretty major part of your motor there. What kind of head gasket is in there that is so great that you don't want to spend another 50-120 bucks to insure that it will seal up right?
Old Feb 4, 2005 | 09:48 AM
PrettyLude's Avatar
do it now and get it over with, or do in an a week or two?
twocross
Feb 23, 2011 03:07 PM
petrv
Apr 12, 2004 12:30 PM
streetlegal gocart
Aug 18, 2003 08:29 AM
jdm-spec-eg
May 22, 2003 02:00 PM
