y8 turbo in a ek coupe
Whats sup im new to the turbo world im usually only a N/A kinda guy. but what kinda performance could i get outta a turbo kit on my stock y8 motor in a 00 ex coupe. Does anyone have any good times from this setup in this body style car?
and another question how hard would it be to use a d-series turbo set up but say i swap out for a gsr later could i use the same turbo setup but just buy a new turbo manifold? any help is apprciated .
PICS ARE WELCOMED
PICS ARE WELCOMED
Re: y8 turbo in a ek coupe (civicrida3)
Your 1/4 mile times and horsepower will depend on your turbo kit and tuning, just do a search if you want more info. You should be able to get into the 13's no problem with a decent setup though. The turbo you would be using on your Y8 will probably be too small for a GSR, but most of the parts should change over.
Re: y8 turbo in a ek coupe (beerbongskickass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass »</TD></TR><TR><TD CLASS="quote">Your 1/4 mile times and horsepower will depend on your turbo kit and tuning, just do a search if you want more info. You should be able to get into the 13's no problem with a decent setup though. The turbo you would be using on your Y8 will probably be too small for a GSR, but most of the parts should change over.</TD></TR></TABLE>
yea thats basically what you are faced with. also spend some time on http://www.turbod16.com.
