Cracked block...Oil pressure sender unit
so heres a big downer....while screwing my oil pressure sender unit back into the block, my retarded *** tightened it too hard and well, yeah....CRACK in the block. Just about 80% of the threading cracked off in two pieces....
What in the hell can I do?...I tried JB weld and that didn't seem to work very well because when I threaded the OPS unit back in just cracked off again...
But, thinking about what JB weld is..it's a mixture of steel and a hardener...the block though, is cast aluminum...so this probably wouldn't work as well as say, aluminum epoxy? Right?
Should I try an aluminum epoxy or something along those lines?
Any suggestion would be great...because I feel like a big terd right now...
Re: Cracked block...Oil pressure sender unit (m R g S r)
I thought of that but...well thats costing money I don't have, so I guess what I'm trying to do is get her running on a cost efficient level...
Thank you though.
Any other suggestions H-T?
Thank you though.
Re: Cracked block...Oil pressure sender unit (Accurate GS-R)
you could screw your oil pressure sender in the head where people feed vtec oil. Then just plug the back of the block. I would only do that if I was stranded somewhere...
Re: Cracked block...Oil pressure sender unit (salt)
Did the same exact thing to my D16.. I tried JB weld too, doesn't work. I had to end up using a larle suspension bolt to plug the hole, but of course I now have no oil pressure warning. GRanted this is only a D16 so I'm not too worried, but if I were you, I'd plug it up and get yourself an oil sandwich adapter (which I will never run without) and run an oil pressure gauge or run a fitting to it that will let you screw the sender onto it.
Re: Cracked block...Oil pressure sender unit (VTC_ohgodnotagain_CiViC)
Holy glorious ****....I didn't even think of that...and I actually happen to have a plug that fits exactly in there!
But first, let my get this straight...the oil pressure sender unit is not necessarily important? It only sends a warning to my dash?
So all in all...it's okay the car without it being hooked up?
Thank You Honda-Tech!!!!!
i think you would have to hook up the oil pressure sending unit for vtec purposes also....the ecu needs the signal to engage vtec
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Accurate GS-R »</TD></TR><TR><TD CLASS="quote">
Thank You Honda-Tech!!!!!</TD></TR></TABLE>
That's correct. You could though just run an oil distribution block off your sammich adapter and put the factory OPS on that (using the bpst adapter). That's what I did. I have both the stock OPS and an autometer oil pressure gauge running off my oil distribution block on my firewall.
Edit: I don't have VTEC, so I'm not sure if it'd need the OPS signal for that or not. I'm thinking no though. I think all that logic exists in the head. Don't quote me though.
vtec has its own pressure switch im running no oem ops at all and my car is fine i would highly recommoned getting a oil pressure gauge
We did this to my block. Tried JB weld...didn't work. We ended up using a 1/8" NPT tap to cut new DIFFERENT threads, then running a 1/8" NPT plug in and slobbing some JB weld around it. It leaks a TINY bit, but once the car heats up, the heat closes the cracks. Now I run a GE sandwich plate for my sensor and to feed the turbo oil.
I will never recommend to anyone to use the oil sending unit as a location to feed oil.
madking411
02-26-2011 02:15 PM
gutted
08-20-2005 09:55 PM
