Holset h1c?????
Old Aug 19, 2012 | 06:51 PM
v8eatrr's Avatar
Default Holset h1c?????
I'm building an fjt/vitara setup and I was looking into a different turbo because my current eBay Ching Chang turbo won't make the power I'm looking for.
I have a chance to pickup a holset h1c that is in great condition, there is no play
So would this turbo be to big???? I'm looking at boosting 18-20psi
And hp goal is around 330-350whp
So I have seen a lot of hy35 on d16's but no h1c's so please share what you think about this turbo and if it would be fine for me to use on this build
Thanks for any advise given negative or positive
Old Aug 19, 2012 | 07:34 PM
TheShodan's Avatar
Moderator
Default Re: Holset h1c?????
Search google for the "Holset users unite" thread.. that will help your answers.
Old Aug 19, 2012 | 07:40 PM
turbohatch96y7's Avatar
I wouldn't use it.
Spend the extra money and invest in the hx35 or hy35 the less compressor blades the better.
That is if your dead set On the holset trend.
Old Aug 20, 2012 | 12:20 AM
92Snatch's Avatar
I ran a H1c on my car...18psi made 380whp and ran 7.20@99-100, if ur getting a good deal and it's in good shape..use it. I had a bullseye exhaust housing for it, came on at 3200-3400 rpm
Old Aug 20, 2012 | 05:16 AM
v8eatrr's Avatar
Looks like I'm going to try it out then because that's some good power
About what rpm range are you building full boost at?
Old Aug 20, 2012 | 06:50 AM
That's the only reason it made good power. Kinda pointless to spend 280 on the housing unless your getting it with the turbo.
Old Aug 20, 2012 | 08:03 PM
v8eatrr's Avatar
Well I'm getting the turbo for 100 so that's cheap enough to try it
And all the seals are good so it can't hurt much but a days work I guess
Old Aug 20, 2012 | 11:47 PM
92Snatch's Avatar
Yeah my housing & Vband was around the 225-235 range, but worth it in my opinion. I LOVED that turbo, decided to do a diff set up so I sold it :/. Hope u have good luck w/it like I did man
philbeesperform
Mar 18, 2014 01:00 PM
naj_ej
Nov 4, 2010 04:44 AM
95accordh22a
Nov 23, 2005 07:30 PM
tan2
Sep 3, 2003 06:40 PM
SinSeven
Jan 20, 2003 09:40 AM
