Identifying Connecting Rods
Old Sep 16, 2012 | 12:56 PM
Khnemu's Avatar
Default Identifying Connecting Rods
Recently picked these rods up for $30 and was wondering what manufacturer these are from. They have 3/8ths head size ARP bolts.
Any help is appreciated.
Old Sep 16, 2012 | 01:03 PM
rich7777's Avatar
Default Re: Identifying Connecting Rods
Crower ?
Old Sep 16, 2012 | 01:07 PM
Muckman's Avatar
Moderator in Chief
5394 is the length so its an LS rod.
Old Sep 16, 2012 | 01:10 PM
Runnerdown's Avatar
Crower puts their name on stuff. There has been a lot of outfits over the years selling h and I beam rods like that with the length in ink. I think it would be difficult or impossible to establish exactly who sold those.
wantboost's Avatar
Who is Mr Robot?
it could be a d16 or ls rod... without lots of measurements you cant tell, normally if its a lot bigger on the little end its an ls, this looks like a d16 rod (the numbers are rod length in inches)
they look like blueprintracing rods but the surface finish makes me think china rod
see link
http://www.alibaba.com/product-gs/51...tegra_D16.html
Old Sep 16, 2012 | 01:16 PM
wantboost's Avatar
Who is Mr Robot?
you need to measure the rods...
these are the measurements for a d16 rod.
- Piston Pin Dia: 0.748" , 19.01mm
- P.E. Width: 0.710" , 18.04mm
- B.E Bore: 1.890" , 48.001mm
- B.E. Width: 0.898" , 22.8mm
if any thing is different its an ls rod
Old Sep 16, 2012 | 01:18 PM
Khnemu's Avatar
The guy that sold them to me said they came out of a B20 short block he tore down but didn't know what brand they were.
Old Sep 16, 2012 | 01:23 PM
wantboost's Avatar
Who is Mr Robot?
they look like probe i beams...
Old Sep 16, 2012 | 01:24 PM
wantboost's Avatar
Who is Mr Robot?
http://www.ebay.com/itm/Probe-I-Beam...f5370e&vxp=mtr
but they aren't all that great for boosted apps... they are mainly designed for high rpm all motor setups, i beams tend to do bad things under boost
Old Sep 16, 2012 | 01:31 PM
rich7777's Avatar
I have Crower I beam rods in my engine. I actually spoke to crower about them and they said they were fine for my FI setup and that they'd handle a lot more power than I was looking for (450whp).
What bad things do you mean ? Are they suppose to bend ?
Old Sep 16, 2012 | 01:35 PM
wantboost's Avatar
Who is Mr Robot?
probe's are designed differently... they are made specifically to be an ultra-light rod for reduced rotational mass... they weigh less than any other i-beam.. probe designed them for high rpm na use only, no nitrous, forced induction, etc.
they only weigh 430g which is very very light. they'll bend and warp under high cylinder pressures and ultimately break. probe even tells you this.
Old Sep 16, 2012 | 01:40 PM
Khnemu's Avatar
Thank you very much wantboost, seems like we found the answer. lol
I suppose I can resell them to someone looking for a N/A rod.
Old Sep 16, 2012 | 01:41 PM
rich7777's Avatar
Ok, I thought you were on about all I beam rods there...
Old Sep 16, 2012 | 01:44 PM
wantboost's Avatar
Who is Mr Robot?
normally you can use an i beam rod like crower up to 500hp (crank) max and thats really pushing the rod... id say a safe boosted power level for something like the probes would be 300-350 but i don;t know anyone thats ever used them on a boosted motor due to their light weight
Old Sep 16, 2012 | 03:56 PM
1FASTHF's Avatar
You must be referring to the Crower Maxi-light rod and not the regular Crower steel billet rod...
Old Sep 16, 2012 | 04:19 PM
wantboost's Avatar
Who is Mr Robot?
i beams, yes, the steel billet rod is an h beam design
Old Sep 16, 2012 | 04:42 PM
ashb82's Avatar
i made 400hp on a set of probe b16 i beams
Old Sep 16, 2012 | 07:15 PM
EsotericImage's Avatar
Retired Moderator
Probe has a private label program for their products.. i wouldnt be surprised if Crower used this program..
On Probes website, they show Scat rods which look like Probes and also the SRP pistons from JE look like Probes as well..
This is just my speculation on the SRPs.. But I wouldnt be surprised if it was true
Old Sep 17, 2012 | 01:45 AM
wantboost's Avatar
Who is Mr Robot?
a lot of companies put the length in ink, crower does not have an i beam design like probe, the rounded machined pockets on the rod are probe's little identifier
K2e2vin
Jun 12, 2006 01:10 PM
cygnusX1
Sep 20, 2004 03:48 AM
asubennett
Mar 1, 2004 11:16 PM
rioninja
Aug 7, 2001 08:08 PM
