LS Block bore question
Old Sep 10, 2012 | 07:10 PM
Einhander276's Avatar
Default LS Block bore question
So there is a guy selling a LS block for $180 here Houston
he says the block is bored .85mm over with new seals and all that jazz.
so my question is that if i buy 81.5mm pistons, will the pistons and rings set right? like is .35mm too much for the piston ring to expand too?
Please lmk
i wanna start my build and this block is gold for me if i can fit the pistons.
getting weisco 81.5mm pistons if that matters.
Old Sep 10, 2012 | 07:20 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: LS Block bore question
thats not even a real overbore... no one make 81.85mm pistons
Old Sep 10, 2012 | 08:23 PM
well i know that lol, i was just wondering if i can use 81.5m pistons? Is that extra .35mm gonna mess up the pistons/piston rings?
Old Sep 10, 2012 | 08:39 PM
88efhatch91's Avatar
Old Sep 10, 2012 | 08:46 PM
wantboost's Avatar
Who is Mr Robot?
it won't work... thats just simple math
Old Sep 10, 2012 | 09:18 PM
EF9_TryMe's Avatar
^This!
Yeah dude, the SETUP in which you speak of is toast.
You should read up on Piston to Wall Clearance, before you start buying a block. Maybe getting a book related to Engine Blueprinting, before piles
of money and more money is just pissing out your wallet.
How do YOU know that the block is even 81.85mm ? Have you measured the piston skirt ?
Zero it out on a dial bore gauge ? Measured the cylinders WITH the Dial Bore Gauge, Zero'd
out ?
Old Sep 10, 2012 | 09:35 PM
Ryank327's Avatar
If you buy it do it assuming you are going to be paying for a whole new bore and set of pistons.
Old Sep 10, 2012 | 10:04 PM
wantboost's Avatar
Who is Mr Robot?
Originally Posted by EF9_TryMe
^This!
out ?
no, he just reposted what he read... hasn't checked **** and probably doesn't know what he's doing based off of the questions in his post... he probably saw somebody build a motor on tv, or saw pictures on a website and figured i can do that
airmaxbri
Feb 26, 2010 12:33 PM
kyden
Jun 12, 2009 08:16 AM
ekVtecPower
Jun 27, 2006 11:18 AM
Tropicana18T
Feb 23, 2004 03:40 PM
boosted3g
Nov 5, 2001 10:13 AM
