Turbo Oil Feed... too small?
What's up guys?
Just got an oil feed/return kit and I'm trying to figure out if the hole is big enough, it doesn't look like much oil will be able to flow. Anyone have a similar setup that works fine?
Re: Turbo Oil Feed... too small?
Depending if you have a ball bearing or journal bearing turbo and what size feed usually determines to some extent whether you may need a restrictor or not.
Ball bearing, with -4 feed, small restrictor generally.
Journal bearing with -3 feed, some don't run one.
It doesn't seem like there's a hard and fast rule though, except that as long as your return is good, if it smokes then add a restrictor.
Retired Moderator
I was thinking the same thing when I saw it.. Those soft aluminum ebay flanges are garbage but i wasnt going to say anything... but after attaching a line to it, i bet it will leak severely.
Id stick to the tried and true inline brass restrictor
Not sure on the size... the hole is a little bit bigger than it looks, but not much. I guess I will try it and if it does in fact leak I will opt for a brass fitting.
OK cause I see where people were saying journal bearing turbos don't need a restrictor, how will I know if the restrictor is a.065? How do I measure the hole?
you order a proper restrictor! Lol! These restrictor flanges like this pictured are not good at all. I'd suggest an actual restrictor fitting; talk to Go-Autoworks. I got the stuff I needed for my GTW setup for 20 bucks, if I remember correctly.
OK thanks my friend, gonna try to see if I can get in touch with go auto works,
Or just buy quality parts one time from a reputable seller. Such as speed trap consulting. They sold me all the correct parts for my turbo. I dont even have to wonder if what I have is correct.
Edit: I couldn't find the original package but I looked up the invoice.. It was a -4AN oil inlet restrictor jet. Greg should know more info from there. Lol!
*Boostwerks*
07-13-2005 01:38 AM
