a QUIET BOV
Old Sep 12, 2012 | 10:15 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default a QUIET BOV
i am a novice in FI world (sort of). i am in need of a quiet blow off valve, around 15-20PSI planned. don't care if recirculating or atmosphere vented.
i would also prefer one without flashy appearance, something like the old Bosch BOVs used in Nissans.
Old Sep 12, 2012 | 10:25 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: a QUIET BOV
tial's are pretty quiet
Old Sep 12, 2012 | 10:46 PM
this looks good
http://www.turbosmartusa.com/product...-universal-fit
are they any good?
Old Sep 12, 2012 | 11:13 PM
wantboost's Avatar
Who is Mr Robot?
they will work, you would need to have a hose barb welded to the charge pipe with a piece of silicone tubing to mount the bov... then you'd have to plumb the recirculation stuff
Old Sep 14, 2012 | 08:25 PM
the BOV will be mated to the carbon fibre charge box.
Old Sep 14, 2012 | 10:13 PM
EsotericImage's Avatar
Retired Moderator
im using the turbosmart raceport 50mm and you dont hear a thing. I like the stealthiness of it. all you hear is the spool up
Old Sep 15, 2012 | 01:31 AM
wantboost's Avatar
Who is Mr Robot?
charge box? without the blow off valve on an intercooler pipe it won't work
Old Sep 15, 2012 | 09:12 AM
the charge box encloses the ITBs. i am designing the box to incorporate the air to water after cooler as one unit.
Old Sep 15, 2012 | 01:39 PM
VTEC+Mini's Avatar
I have a Tial BOV and when I giddy-up it sounds like the car is sneezing when I shift. Not loud but definitely not stealth. Of course they may believe the car realy does have have hay fever as the whole thing is stealth.
Old Sep 16, 2012 | 12:51 PM
drummerdude's Avatar
you say you are a novice in FI, but you plan on putting together a system with ITBs, and a custom charge box with an aftercooler in it? ssems a bit complicated for a novice. I don't want to discourage you, but if you are truly a novice you should do alot of searching, followed by a simple first system to get your feet wet. just my .02
Old Sep 16, 2012 | 03:51 PM
got-vtec?'s Avatar
why would you want a quiet bov? thats like having a quiet partner during intercourse lol
Old Sep 16, 2012 | 04:08 PM
I prefer a quiet BOV
Old Sep 16, 2012 | 04:11 PM
I used to be able to hear the 2 srt4s that lived in my neighborhood anytime they left the house, even 10+ blocks away.
Old Sep 16, 2012 | 04:20 PM
wantboost's Avatar
Who is Mr Robot?
my neighbor has an srt4 with the mopar block off plate, i never, ever hear his blow off valve... its all in how you drive the car
Old Sep 16, 2012 | 04:35 PM
v8killaz's Avatar
probably all with stock turbos that spool at idle and cars slow as *****
Old Sep 16, 2012 | 08:20 PM
Retired Moderator
I like my women like my coffee
ground up and in the freezer..lol
Old Sep 16, 2012 | 08:53 PM
i am being facetious, plus i really mean, i do not know who makes good stuff. the other things mentioned are all fabrication.
i have also made a custom ECU and the harness for it
Turbo_TONY
May 10, 2006 06:12 AM
1FastCoupe
Aug 18, 2005 07:59 PM
raSIturbo
Oct 27, 2003 04:33 AM
