B18 turbo running lean
Old Sep 6, 2012 | 08:00 PM
EGdope's Avatar
Default B18 turbo running lean
Well I traded my integra for this last night and i drove it all day and used 3/4 my tank. No problems at all the whole day till this.
I went and picked my little sister up from her soccer game and I was sitting there waiting and left it running for a good 3 or 4 minutes, i revved up after she got in and my A/F ratio went from a normal 12 or 13 to 17, 18, 19.
So I hurried up and drove home which was only a mile down the highway. I got home fine let it cool down for a good 2 hours. I started it up and it idled a little funny like it was missing and the r/f was at like 14 15 and i revved it up and it went to 18 then 19 then 20 and then it died and it read LEAN.
Right now its dark and I have no light to use so in the morning im gonna check the fuel pressure and the spark plugs and see if they are good then go from there.
This is my first turbo car and dont really have a whole lot of experience with forced induction. Im learning as I go.
I ******* love boost
AEM fuel rail
550 cc rc injectors
255 lph fuel pump
Old Sep 6, 2012 | 10:57 PM
PTVDesign's Avatar
Default Re: B18 turbo running lean
maybe cracks on downpipe before o2 sensor?
Old Sep 7, 2012 | 03:13 AM
Turbo-LS's Avatar
It needs to be tuned more . The intake temp corrections are not adjusted properly and as the temp rises its taking out fuel instead of adding or stayin he same
Old Sep 7, 2012 | 04:55 PM
EGdope's Avatar
I changed plugs this morning, didnt bother starting it and seeing if it was fine which was stupid. Car ran fine for a good hour and then it started to do it again. I'm seeting an appointment with a tuner here soon
Old Sep 7, 2012 | 09:31 PM
Dynasty21's Avatar
From: Where We Squeeze 1st N Ask Questions Last, CA, USA
Check all pipings and bolts, make sure there aren't any leaks. My a/f leaned out when my wastegate bolts came off.
Old Sep 7, 2012 | 09:34 PM
SwappedTURBOegg's Avatar
dizzy is my guess
Old Sep 8, 2012 | 12:07 AM
wantboost's Avatar
Who is Mr Robot?
either this or your IAT sensor took a ****
Old Sep 24, 2012 | 09:25 AM
EGdope's Avatar
I have No CEL but its still doing it after I replaced the plugs AGAIN with .35 gap (Is that too much?)
Old Sep 24, 2012 | 09:57 AM
phaphon's Avatar
are you using cold apark plugs?
Old Sep 24, 2012 | 10:02 AM
mtber's Avatar
You are judging your air fuel ratios with no load on the engine.
You should be running a 7 or 8 heat range plug gapped to around .028
Recommended Target Air Fuel Ratios On 91-93 Octane Vehicles:
Forced Induction Vehicles: 11.2-12.0:1 (Full Throttle)
Partial Throttle/Idle: 15.5:1 (Light Throttle) 14.7-13.6:1 (Partial to Mid Throttle)
There are many small variables involved in targeting your air/fuel ratios, the main idea is to ensure you are not running too rich or lean & making the safest & best power possible due to maintaining a proper amount of fuel to your motor at all times.
Freeltec
Apr 24, 2007 09:52 AM
cliff666
Aug 1, 2004 11:04 AM
Integra99GSR
Nov 23, 2003 01:25 PM
sneakypete
May 29, 2003 02:35 PM
HondaCutter
Mar 17, 2002 08:26 PM
