b18b1-turbo map issues
Old Aug 27, 2012 | 12:01 PM
buckner2009's Avatar
Default b18b1-turbo map issues
hi there cats got a b18b1 cast blox mani junk ebay turbo dsm 450cc 3 inch exhaust i tune myself on crome say what u want its junk its good blaaa hondata not looking for that here-
ive done turbo builds on sohc currently have a kid on the way, 100k on motor leakdowns good running 5 pounds on a tdo4e ejunk - looking for around 9 psi, tuning it not hard part wondering from any real tuners what they set there timing map to with stock internals on healthy motor - by that i mean say 9 pounds 7200 im at 19* that to much or not enough? advice welcome tips hints - and restrictor in turbo -? some say dont run them some say do tips -
Old Aug 27, 2012 | 12:18 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: b18b1-turbo map issues
what the **** did I just read?
english, grammar, punctuation, spelling, etc. All not your friends apparently.
Old Aug 27, 2012 | 01:00 PM
lsvda's Avatar
Why do you always have to be a smart as*!
as for your question 19 degrees is fine at 7200 at 9lbs on a sohc fine cuz of the small displacement whats the timeing peak at befor it dropes to 19
Old Aug 27, 2012 | 01:25 PM
wantboost's Avatar
Who is Mr Robot?
haha, I try not to be... but it jst rambled. I really couldn't make out what he was asking.
he's on an ls block, not sohc. so I'm not sure if 19* is best for his setup... I don't imagine he's making much over 250hp (if that) with that small of a turbo. although there are a lot of variants with a td04e compressor housing... but nothing too fabulous. The turbine side of the turbo kills any power potential so I'd say maybe 200-225hp. OP does this sound right to you?
Old Aug 27, 2012 | 02:56 PM
sorry yes my grammer sux no need to b rude -_+ but every think up there full throttle is 19* at 5 pounds if i was to run 8 psi like want to its still at 19* and the setup is this .... rebuilt stock everything gsr tranny blox mani tial knock off huge 3 inch intercooler 2.5 inch charge pipes turbo to manifold dsm450cc with wideband 11.5 full throttle 13.5 like partial till full boost- turbo is .63 hotside cold side just says to4e- that little better and it is a b18b1
Old Aug 27, 2012 | 02:59 PM
just trying to figuare out were my timing should b for good dd all around power and goal is honestly like 220ish- map set to 1 degree removed and i did pull out little more timing at 5psi . o i am running bkr7e plugs gapped at 32 thousands i believe what put them at
ZCHondaCRX91
Engine Management and Tuning
Sep 13, 2017 07:59 PM
CE1318
Feb 20, 2017 07:17 PM
aznpreludeSH
Aug 17, 2009 04:52 AM
nudvl
Apr 29, 2005 06:56 AM
95cxhatch
Jan 27, 2005 09:23 PM
