is this a rod knock? video inside
Old Sep 3, 2012 | 10:24 AM
golf-mk3's Avatar
Default is this a rod knock? video inside
so this sound started today after driving the car, it got louder gradually. it first started doing it when i rev the motor now its also doing it at idle.
the sound feels and sounds like its right under the valve cover
last time i drove the car i miss shifted going from 3-4 and went to second but realized it very quickly and hit the clutch. the car ran good for the rest of the night after that.
Old Sep 3, 2012 | 10:41 AM
sanman000719's Avatar
Default Re: is this a rod knock? video inside
ummm thats an issue for sure man 2 things come to mind rod slap or valve slap
Old Sep 3, 2012 | 10:53 AM
golf-mk3's Avatar
valve slap is in valve hitting piston?
Old Sep 3, 2012 | 10:55 AM
yah man check the crank/cam gears for timing to see if the belt didnt slip
drop the oil pan and see if any rod is broken
Old Sep 3, 2012 | 10:58 AM
non-VTEC's Avatar
defiantly rod knock...tear it apart...
Old Sep 3, 2012 | 11:04 AM
the shift issue was the only reason i thought valve
Old Sep 3, 2012 | 11:41 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
It could as be bad lma's. Had a set go out on the dyno. Bisi pulled out the scope to help find the issue. I sure thought it was the bottom end. Turned out to be stuck lma's. Switched out to the new s2k and went back to tunning.
Old Sep 3, 2012 | 01:26 PM
ashb82's Avatar
take off you oil filter and cut it open i bet it looks like these pics
Old Sep 3, 2012 | 01:30 PM
DDTECH's Avatar
rod knock
broken rocker arm flying around
valve slap or piston slap
Either / or, this motor needs to be torn down..in for carnage pictures as thats always fun to look at.
Old Sep 3, 2012 | 01:38 PM
lol agreed
Old Sep 3, 2012 | 02:27 PM
Turbo-LS's Avatar
Ouch! I love how he keeps revving it up like its not heard loud enough at idle. Bearing defiantly gone on at least one cylinder. Probably on the way out on others also
Old Sep 3, 2012 | 03:07 PM
rclark's Avatar
lol LMA's sound nothing like that
Old Sep 3, 2012 | 05:23 PM
crvtectim's Avatar
Ewww, in for destruction.
Old Sep 3, 2012 | 05:24 PM
blackeg's Avatar
https://honda-tech.com/forums/forced-induction-16/alright-peeps-lets-play-diagnose-noise-3080885/
ehhhh
at the beginning of the vid i was convinced it was bad lma's, it sounded just like my car. then it revved up and it really sounds like a rod knock.
KennyD87
Classic Hondas
Sep 17, 2015 09:48 AM
Hatorade
Jul 16, 2013 07:29 AM
JdmCrx209
Dec 24, 2011 07:08 AM
blasta510
17
Dec 19, 2011 11:17 AM
